Serpent 710
#1623
Originally posted by sparksy
Maybe he had an Impulse PRO?
I actually have the same blue and red allen drivers as in the pics. I believe they are from Team Magic but I don't think they make them anymore. I'm still trying to locate the spare tip for the 2 mm allen (red handle). Besides the Hudy, those are my favourites actually as they allow your to tighten allen screws tightly by forming a T wrench when you slot an allen driver in the hole of the other handle.
#1629
Originally posted by Julius
D, there might be a day when it doesn't rain!
What's the weather like now?
#1630
Originally posted by Thaasman
If you're mounting the(Don't know the name
) Big aluminuim screws for the pivot balls... Use a HUDY tool, otherwise you can't get them straight in
#1631
Originally posted by InitialD
Pivot ball retainer adjusting screws (808344)? So they still do not line up straight? Yes, they require 10 mm allen drivers. The Hudy Glowplug (107581) is the one you're reffering to, right?
SN
#1632
Well mine is almost finished but i can't get the reciever protector mounted if all the wires are connected, and i'm using a futuba micro reciever...
#1633
Originally posted by S710_Nut
Won't a normal allen key work?
I find that the normal L shape allens would be difficult to mount it straight. Don't know why. Perhaps we lack assembly skills !
#1634
I guess if you have a T type allen driver, it would be easier to align the nut to retain the pivot ball like the Hudy Glowplug wrench.
SN
#1635
From the ones that I have built (705 / Impulse), a slight tilt will make the pivot ball retainer screw slant. The threads a corse and rough. So it does not leave you with a lot of margin for error.
What I do is I grease these pivot ball retainer screws a little. Thread them by hand into the steering knuckles as far as I possibly can and use the Hudy tool to slowly screw them in. Once you see them begin to slant, back out and do again.
