Serpent 710
Old 12-15-2003 | 03:04 AM
  #1651
Ok, the stock front shock rod/pin is way too fragile!! Anyone use shock rods other than the stock? I broke 3 of them each day!
lawndoggie is offline
Old 12-15-2003 | 03:55 AM
  #1652
Thaasman's Avatar
Originally posted by InitialD
Thaasman, nice pics ! No engine? When are you taking the car for a spin? hehehe
No i'm waiting for the nova mega KHM...
And like lawndoggie said, it's too cold!
I have to wait for another 2months or so...
Thaasman is offline
Old 12-15-2003 | 03:56 AM
  #1653
Thaasman's Avatar
Post
Originally posted by lawndoggie
I think its very cold in belgium!?? Perhaps you should send me your 710, and I can run it in for you... so when you get it back in the summer, it will be well broken...
in....
nice try
you evil dude
Thaasman is offline
Old 12-15-2003 | 04:02 AM
  #1654
tranced's Avatar
would you mind taking close up pics of the rear "active" suspension? (ie. lower rear front wishbone)
tranced is offline
Old 12-15-2003 | 04:14 AM
  #1655
Thaasman's Avatar
Post
Something like this?
Thaasman is offline
Old 12-15-2003 | 04:21 AM
  #1656
InitialD's Avatar
lawndoggie, perhaps Serpent needs to come out with a lawndoggie version of the shock shafts !
But seriously, the shafts are OK. At least if you stop hitting the knuckles / shock shafts against the boards and walls.
InitialD is offline
Old 12-15-2003 | 04:24 AM
  #1657
InitialD's Avatar
Thaasman, I was just messing with ya... I know that it's cold over where you're at and I thought that I poked fun at you not being able to run the car even after you finished building it ! Anyway, all is good.
Ummm, shouldn't the car be under the Christmas tree?
InitialD is offline
Old 12-15-2003 | 04:30 AM
  #1658
Thaasman's Avatar
Post
Yeah if i had one allready, can't afford one now i bought the 710
I hope julius can give me some answers about the reciever protector..
I'm using the one that comes with the futuba 3vc
you can see it in one of the pictures too..
Thaasman is offline
Old 12-15-2003 | 04:40 AM
  #1659
sparksy's Avatar
I dont think you will get a different answer other than your servo is too big.
Same thing when the 705 and 835 came out... they are not designed to run the older bigger recievers.
sparksy is offline
Old 12-15-2003 | 04:46 AM
  #1660
Thaasman's Avatar
Post
but i have i MICRO reciever...
How small must it be
Thaasman is offline
Old 12-15-2003 | 04:55 AM
  #1661
sparksy's Avatar
ok.. it is a little one..
But that was the answer we got from serpent when the futaba recievers wouldnt fit the 835 without some milling work to the chassis.. and they were the small ones at the time.
Why exactly wont it fit? Can you modify the holder? Can you take a pic of the holder without the reciever and cover on it?
sparksy is offline
Old 12-15-2003 | 05:06 AM
  #1662
Thaasman's Avatar
if i put on the protector on the holder, the crystal of the reciever is in the way,and the connectors,if you turn the reciever, the holder is in the way
Thaasman is offline
Old 12-15-2003 | 05:14 AM
  #1663
sparksy's Avatar
I personally would cut the cover to clear the xtal and connectors. Might not be the best option though.
You could try the cover from the Mugen MTX.. some of the Kyosho guys are running them on the V-one R evo....
Or you could simply not run the cover at all.
Or you could make one to fit out of some thicker lexan or styrene.
sparksy is offline
Old 12-15-2003 | 05:19 AM
  #1664
Thaasman's Avatar
I was thinking that too but i'll wait a bit , see what julius has too say about this..
Because i can't imagine that any reciever would fit
Thaasman is offline
Old 12-15-2003 | 05:49 AM
  #1665
fastharry™'s Avatar
From: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
I certainly wouldn't run it like that...with no cover..
fastharry™ is offline
