Old 09-30-2004, 07:51 AM   #16651
markp27's Avatar
Send a message via ICQ to markp27
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: New Mega's
Originally posted by Sow&Steady
This now makes sense. I've tried the 17-61 without problems at all and after this weekend's race (errr, maybe kicking Mark's a$$ ) ) I'm going to try the 16-60 combo.
AHA! You've given the plot away again, Sow
markp27 is offline   Reply With Quote
Old 09-30-2004, 07:52 AM   #16652
Sow&Steady's Avatar
Originally posted by InitialD
Thanks for the info Julius. Are you making a stop in Brazil for the worlds?
Julius, I think this is another one of those "gentle, gentle, slowly" thing hoping to get a free ride in the luggage haul to Brazil.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 09-30-2004, 07:59 AM   #16653
Sow&Steady's Avatar
Default Re: Servo Saver Clearance
Originally posted by sparksy
Ok, so here is a close up of where it hits when the new part is installed. Both mine and Picards have hit here. We just shaved off a little of the bulkhead to allow it to clear...
Sparksy, thanks for the pic. I think this is a small price to pay (i.e. if it just takes a small shaving off the bulkhead) for the added steering and less risk of the rear stepping out as per Julius's input.
Old 09-30-2004, 08:51 AM   #16654
Pyramid's Avatar
Originally posted by Picard
In my experience I have found that the car is easier to drive with a softer setup but it lacks response in my opinion. I have always found a harder setup to give a quicker car reaction, in turn giving you less room for error. This weekend I am trying 40W oil instead of the 30W i have been using
Let"s say everyting else remain the same, you only change to softer dampening (means lower on both oil and spring rate alltogether).. this will make the car rolls more.. I think it can only react quicker and harder to drive if using softer oil but harder springs. Sure, driving style plays important role as well.
Pyramid is offline   Reply With Quote
Old 09-30-2004, 08:58 AM   #16655
Picard's Avatar
OK..Agreed on the driving style, that is definately a factor.
The softer dampening that you mention I understand but if the car is rolling more then the reaction is slower because it is rolling. If you are running hard dapening the car is not rolling as much therefore reacting quicker.
Picard is offline   Reply With Quote
Old 09-30-2004, 09:07 AM   #16656
Picard's Avatar
Pyramid
I think what you are saying is that the dampening reaction will be faster will the softer dampening which I agree but I am talking about the car reaction.... for eg..a chicane where the car has to change direction quickly, or also cornering. I want the car to be quicker reacting than it is at the moment
Old 09-30-2004, 12:15 PM   #16657
Herbie's Avatar
Pyramid
You can also lower your frontrollcenter to get a faster steeringinput. Try different settings and you'll be surprised
Herbie is offline   Reply With Quote
Old 09-30-2004, 06:13 PM   #16658
Send a message via AIM to kreidel
How is it now hitting the bulkhead? That is not the new part so how would it change anything? I installed the new saver and it did not change the clearence on mine.
kreidel is offline   Reply With Quote
Old 09-30-2004, 06:52 PM   #16659
Pyramid's Avatar
Like I said, leave the red springs and put around 40WT Trinity grade oil.
Old 09-30-2004, 06:54 PM   #16660
crashed_1's Avatar
This now makes sense. I've tried the 17-61 without problems at all and after this weekend's race (errr, maybe kicking Mark's a$$ ) I'm going to try the 16-60 combo.
Sow, I've been running 16/61 for the past 20 tanks without stripping or modding. I can't seem to figure out what i did wrong in the past but it seems to work fine now.... Mebbe it's better meshed with a smaller 2nd gear pinion. 16/61 and 21/56 is my current combo. Oh yah, I've tried it on both blk and bronze pinions and they both work....Strange but true...
crashed_1 is offline   Reply With Quote
Old 09-30-2004, 06:54 PM   #16661
Pyramid's Avatar
To the drivers steering input it's true, but how come less roll=more steering?
Old 09-30-2004, 08:51 PM   #16662
InitialD's Avatar
OK..I have just put in 40W oil and red springs because the car feels a bit lazy at times. My problem with modifying the pistons is that it seems like it would be the same as putting 35W in my shocks with standard holes? Or 40W with 1.2 holes?
I once asked the same question and Julius did reply that the effect is not the same when putting thicker oil with more holes and using softer oil with less holes. They feel the same but they are actually not.
Old 09-30-2004, 08:54 PM   #16663
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: New Mega's
Why "surely NOT 61"??? This is the combo which gives the best acceleration and for small tracks this is the combo which is best.
Onkel Sow, if you have to use 16T pinion, you could use 16/60 combo which gives 7.03 FDR. 16/61 combo gives 7.15 FDR. You will note that if you want to get the same rollout as using 16/61 when using 16/60, you need to use 1 mm smaller tires all around when you're on 16/60 to achieve the same kind of acceleration.
I am not suggesting the answer IS to make the 16 bigger either. Maybe the answer is ta make the 61 slightly larger in diameter instead?
Making 61T larger would defeat the purpose I think since you'll have meshing problems with other 17T and 18T 1sy gear pinions.
Old 09-30-2004, 08:54 PM   #16664
InitialD's Avatar
I have struggled to get the power to the ground with that combo, tried lots of different car settings myself, I think that is what julius means but could be wrong
From what you say about you needing to use softer springs and hard to get the power down, it sounds like the track you run on is pretty loose. Softer tires perhaps?
Old 09-30-2004, 08:57 PM   #16665
InitialD's Avatar
