Serpent 710
I have also 2 questions.
1) See manual : modellirc.it/pdf/manuale710.pdf
I could not find this shim in my kit and nothing about it in my manual.
Should I buy this shim or I have latest release of S710 kit and I don't need this shim at all ?
2) In my manual in step 8.1 has sentence, something like : Please don't use cone washer from engine, but only from S710 kit, but I had no cone washer in bag 35. Is it important ? from my point engine cone washer fits ideally.
Step 8.4
Assemble the gears and the clutch housing. Use the thin shim (#802511)
between the two gears. Use the supplied pinion
gear tools to tighten the gears.
A) Note placement of the thin shim.
2. If the cone fits on the engine crankshaft and into the flywheel properly, no problem.
Hey Sam, I've never run the car and just recently installed the gear diffs. From what I've read, the solid front axle takes away a lot of off-power steering so I figured I'd throw the diffs in while I had the chassis apart.
Rear diff 30,000 cst
30k front 10k rear for good grip. Good off power steering and you can still power out of the turn, good balance overall. try the same shore tires front and rear for this setup (or not very far apart like 40 front 37 rears).
