Old 05-07-2008, 06:13 PM   #23326
Mike Schumacher's Avatar
Trader Rating: 36 (100%+)
I know the front running a bit faster than the rear on the stock setup. I believe rubber tires need the same speed all around.
Mike Schumacher is offline   Reply With Quote
Old 05-24-2008, 12:18 PM   #23327
mmario777's Avatar
Trader Rating: 15 (100%+)
Does anyone tried the CRF Serpent clutch conversion for 710
the spring look a lot ticker then the stock one or is better to stick to the original clutch weights/shoe and the 1.8 spring ser#909518
mmario777 is offline   Reply With Quote
Old 06-30-2008, 11:49 PM   #23328
Default Serpent USA Warehouse Clearance Sale
Take advantage of incredible prices on spare parts for the following models
http://www.serpent-usa.com/es12801024/index.htm
For more info and to order, e-mail [email protected] or call (305) 639-9665
Paolo M is offline   Reply With Quote
Old 07-13-2008, 08:52 PM   #23329
Default ball bearings
i am going to be taken my 710 apart for the first time to clean it, I has wondering how to take off the rubber seals on the ball bearings and is it easy to put back on.
rcjayy is offline   Reply With Quote
Old 07-13-2008, 09:24 PM   #23330
Send a message via AIM to Profoxcg
wow its been years since i posted on here. anyway, take an xacto knife and pic the seals off carefully, then use some of the spray cleaner "nitro cleaner" i remember taking the grease out when I was bulding my car and putting bearing oil.. well after your are done, just press the purple seal back on. - done !
I miss my 710
Profoxcg is offline   Reply With Quote
Old 07-14-2008, 09:23 AM   #23331
thanks
Old 07-14-2008, 10:58 AM   #23332
Casey Belarde's Avatar
Default serpent set up
need a good set up for a serpent 710 for open smooth asphalt track lay out, long straights.
Casey Belarde is offline   Reply With Quote
Old 07-15-2008, 10:46 AM   #23333
I know there is probably one In the 100's of post but I don't want to spend hours searching
any setup help would be greatly appreciated
Old 07-15-2008, 12:14 PM   #23334
dj apolaro's Avatar
I will try to find something from my old stuff.
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 07-05-2009, 11:53 AM   #23335
boba's Avatar
Hi Serpent Guru !
I am new in on-road. Just bought Serpent 710 kit and assembled it. Tried to mount LRP 0.12 and found this engine doesn't fit to car, see picture : Tank-bracket, rear, prevents to open carburetor. What is my mistake here ?
Thanks in advance for the help.
P.S. Sure I can start to saw Tank-bracket, but just wondering if I am only one who have this problem ?
boba is offline   Reply With Quote
Old 07-05-2009, 12:02 PM   #23336
evanwest94's Avatar
Send a message via AIM to evanwest94
Hi, I was wondering if Serpent 710 parts will fit my Serpent 705
http://unclefrankensteinsrctools.yolasite.com/
--------LOOK AT MY TING-TING!!!----------
evanwest94 is offline   Reply With Quote
Old 07-05-2009, 02:31 PM   #23337
Julius's Avatar
Originally Posted by boba View Post
Hi Serpent Guru !
You;ll need to rotate the carb a bit. Loosen the screw on the engine that clamps the carb, just below the carb, and rotate the carb about 10 degrees.
You may still need to cut away a little material on the tank bracket depending on the engine though.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 07-05-2009, 02:33 PM   #23338
Julius's Avatar
Only a few bearings, the 2speed and the front steering blocks.
Possibly some hardware like the pivot balls etc.
Old 07-05-2009, 02:39 PM   #23339
boba's Avatar
Thank you very much for the answer, I did exactly the same, can not only believe Serpent did so bad solution or LRP engine is very specific and other are fit to S710 perfectly.
Old 07-05-2009, 03:39 PM   #23340
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Thats always been like that. You have rotate the carb on all the onroad cars. Also, you may have to bend the throttle rod too. Its been years since I've worked on a touring car, but I remember working the carb and linkage to clear.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
