Serpent 710
Old 07-13-2005 | 09:50 AM
  #21841
nigelnuggets's Avatar
Originally Posted by markp27
The shocks are less prone to breaking when you mount them like Joe suggests, as they are no longer at a slight angle, where they are already under a slight bit of stress. If you then have a frontal crash, it doesn't take much to snap the rods.
ill try that sometime. 90% of my crashes include people hitting me from the side, but if i get into another frontal impact ill be sure to try it.
thanks guys.
Originally Posted by Julius
The new shocks fit better. They don't need reworking to have some free movement.
new shocks? 960?
Originally Posted by New_Toasted
Or just the shockmod?
shockmod?
HAHAHA go me.
nigelnuggets is offline
Old 07-13-2005 | 02:50 PM
  #21842
Julius's Avatar
Originally Posted by sparksy
Lets just hope you keep your crashing to you after work hobbies!!
Julius is offline
  #21843
Julius's Avatar
The new shocks as in the new 960 shocks? Or just the shockmod?
The new 960 shocks
Julius is offline
Old 07-13-2005 | 11:14 PM
  #21844
Darth Vader's Avatar
The new 960 shocks
When will these shocks be available to the rest of the world?
Part # please...
Darth Vader is offline
Old 07-13-2005 | 11:39 PM
  #21845
The new 960 shocks
wowow im so interested. i heard they have a high volume? or something like that, glenn williams owner of the race place here in the greater LA area was telling me about them.
what is the exact difference anyways?
Old 07-13-2005 | 11:57 PM
  #21846
acutts's Avatar
http://cgi.ebay.co.uk/ws/eBayISAPI.d...sPageName=WDVW
acutts is offline
Old 07-14-2005 | 05:52 AM
  #21847
Pyramid's Avatar
Registered User
Part # please...
903164 Front Shock Set
903165 Rear Shock Set
Should be available beginning to mid of August... yes, year of 2005
Pyramid is offline
Old 07-14-2005 | 06:03 AM
  #21848
Pyramid's Avatar
Registered User
All nylon parts has been redesign.. machined shock piston will be available as well from 1 to 4 holes.
Everything you imagine about the shock is different: starting from foam insert to the way you fill the oil in and bleed them are all hapening from the bottom parts. Yes, the whole top it just considered as an housing, things are the other way around now... I think I remember someone mentioned `truly Serpent R&D`
Pyramid is offline
Old 07-14-2005 | 06:26 AM
  #21849
daniz24's Avatar
Regional Moderator
I forgot which car, but I think the system is the same as Team Atlas or Tech Racing cars on EP
daniz24 is offline
Old 07-14-2005 | 06:45 AM
  #21850
Pyramid's Avatar
Registered User
if interested, don`t place comment, place preorder please (j/k)
Pyramid is offline
Old 07-14-2005 | 07:18 AM
  #21851
markp27's Avatar
Send me a free sample Pyramid and I promise to tatoo Daltonshop on my arm
markp27 is offline
Old 07-14-2005 | 08:00 AM
  #21852
daniz24's Avatar
Regional Moderator
good idea
daniz24 is offline
Old 07-14-2005 | 08:13 AM
  #21853
Pyramid's Avatar
Registered User
and I do not even have one but I bet if you asked Rene with the compromise that you metioned above, he will definetely pass you a set
Pyramid is offline
Old 07-14-2005 | 08:27 AM
  #21854
Having not seen an actual product i.e. wild e-speculation here, it sounds very much like shocks you find in Losi buggies - which have been out for donkeys so the "truly serpent R&D" might be a tad generous . Having said that, they don't have the hole adjustment feature, or at least when I stopped playing with buggies - can't get to a track
one-nil is offline
Old 07-14-2005 | 08:44 AM
  #21855
markp27's Avatar
Swoooosssh!!!
markp27 is offline
