Serpent 710
#1636
Originally posted by InitialD
Pivot ball retainer adjusting screws (808344)? So they still do not line up straight? Yes, they require 10 mm allen drivers. The Hudy Glowplug (107581) is the one you're reffering to, right?
#1637
Originally posted by S710_Nut
I would have thought you could line it up and start to screw it in with your hands? I haven't built a serpent though...
SN
SN
Really.....
#1638
SN
SN
#1639
Originally posted by Thaasman
No it is not possible to fit them straight wit a normal L key...
Really.....
Really.....
#1642
The ONLY way to fit it propperly is to use a HUDY glow plug key
But in any case, I believe no one should do without this glow plug tool since you need it to tighten down the flywheel nut onto the flywheel.
If ever was there an award for the best glow plug wrench, this would be it. Made with Hudy springsteel, it will outlast any car.
#1644
For the pics:
I use a sony4.0mpxl didital cam.
Anybody knows how i reduse the pixels(on pc) so i can post them??
For the pics:
I think it should be under the pics quality section in the camera. That should give you a smaller file size suitable for posting on this forum.
#1647
What size hudy nut driver do i need for the 710 and do you have a part number for the hudy glow plug key?
I just posted the part number for the Hudy glowplug wrench. It's 107581.The sizes should be the same as building the 705;
1.5mm Hex Allen Wrench
2.0mm Hex Allen Wrench
2.5mm Hex Allen Wrench
3.0mm Hex Allen Wrench
5.0mm Hex Allen Wrench (can be gotten from the Hudy Glowplug wrench)
7.0mm Hex Socket Wrench
4mm Phillips screw driver
5mm Phillips screw driver
If you can get the ball tip type of allen drivers, get the ones for the 2 mm and 2.5 mm driver. Useful for those hard to reach places.
