Serpent 710
Old 09-30-2004 | 03:11 AM
  #16636
Julius's Avatar
Default Re: New Mega's
Originally posted by 840918001
Hi Julius,
I saw Micheal Salven tested the new Mega's and looking not that fast.
Koen Geurds did use his own modified Nova Rossi, and had some more power.
Why is it? Is it because he was testing relaiability or did he not had the proper gearing?
Bye, Thomas
I don't follow all testing sessions. He might have been testing with pipes as we are working on a line to complement the engines. Also on the Heemstede track gearing ant especially tire size have a big influence on power and topspeed.
Julius is offline
Old 09-30-2004 | 03:12 AM
  #16637
Default Re: Re:
Hi Julius,
Thanks for the info
Hope to see more of the engines soon.
Thomas
840918001 is offline
Old 09-30-2004 | 03:28 AM
  #16638
Picard's Avatar
Default Re: Re: Shock Holes
Originally posted by InitialD
I don't think they are available. That's what MS mentioned in the Talk Backs of one of his race reports. Something to do with the mold.
So the only option is to use a 1.2 mm drill bit and open up the existing 1 mm holes. I know it's difficult on the adjustable ones. That is why I use the fixed number of holes type of piston. Easier to drill but the down side is it is not adjustable.
Thanks for the info
Picard is offline
Old 09-30-2004 | 03:30 AM
  #16639
Picard's Avatar
D
Did you find any advantage with the 1.2 holes...seems like a bit of work
Picard is offline
Old 09-30-2004 | 03:39 AM
  #16640
InitialD's Avatar
Using it with thicker shock oils make the car feel more grippy on certain tracks while still making it stable and not lazy.
I had a few sets of shocks around and with too much time. I work with the fix hole set of piston. Not the adjustable ones. Easier to drill. Yeah it's a lot of work but if you're like me who like to tinker a lot, then it's kinda fun and the findings are pretty satisfying.
InitialD is offline
Old 09-30-2004 | 03:51 AM
  #16641
Picard's Avatar
OK..I have just put in 40W oil and red springs because the car feels a bit lazy at times. My problem with modifying the pistons is that it seems like it would be the same as putting 35W in my shocks with standard holes? Or 40W with 1.2 holes?
Picard is offline
Old 09-30-2004 | 04:18 AM
  #16642
sparksy's Avatar
Default Servo Saver Clearance
Ok, so here is a close up of where it hits when the new part is installed. Both mine and Picards have hit here. We just shaved off a little of the bulkhead to allow it to clear.
sparksy is offline
Old 09-30-2004 | 04:20 AM
  #16643
packetdreamer's Avatar
Originally posted by sparksy
What gave it away? Was it the fact that it was under the 1/8th products?
i didnt even notice . however, they are the same size as the standard shock.
packetdreamer is offline
Old 09-30-2004 | 04:38 AM
  #16644
Pyramid's Avatar
Registered User
Most of the times, lower spring rate combined with lower oil gives you more cornering speed (very noticable on bigger flowing track at any traction condition). Yes, harder to drive since you always need to filled with enough throttle power right after going into the corner or you will 'break' the rear traction.
No they are not the same in terms of speed flowing through the piston holes but it might have the same hardness feeling.
Pyramid is offline
Old 09-30-2004 | 05:22 AM
  #16645
Julius's Avatar
These are the adjustable shocks of long ago....
They work nice when put together perfectly. But the adjustment O-ring would often come unseated and make the shocks inconsistent. Also for ease of setup comparison the step-adjustment shocks are way better.
Julius is offline
Old 09-30-2004 | 05:46 AM
  #16646
Picard's Avatar
In my experience I have found that the car is easier to drive with a softer setup but it lacks response in my opinion. I have always found a harder setup to give a quicker car reaction, in turn giving you less room for error. This weekend I am trying 40W oil instead of the 30W i have been using
Picard is offline
Old 09-30-2004 | 06:41 AM
  #16647
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: New Mega's
Originally posted by Julius
We cant make the 16T bigger. It would make things worse. I've been running the 16T in combination with 59 at the Euro's and been testing with the same gears for a while here at Heemstede. Seems not to be a problem.
If you run 16T I suggest using 59 with it. Maybe 60 but surely NOT 61!
Why "surely NOT 61"??? This is the combo which gives the best acceleration and for small tracks this is the combo which is best.
I am not suggesting the answer IS to make the 16 bigger either. Maybe the answer is ta make the 61 slightly larger in diameter instead?
I was just waiting an answer from Serpent and if you (as a rep of Serpent) are suggesting that that particular combo should not be used than I suggest this is announced at myTSN or maybe place a note in the current spurs or pinion packages which are not recommended as a combo.
Sow&Steady is offline
Old 09-30-2004 | 06:43 AM
  #16648
Picard's Avatar
I have struggled to get the power to the ground with that combo, tried lots of different car settings myself, I think that is what julius means but could be wrong
Picard is offline
Old 09-30-2004 | 06:45 AM
  #16649
Sow&Steady's Avatar
Actually the track of the Euro's in Austria was quite small with lots of hairpins. The new saver was better there too.
It gives a little more steering in the corner and a little less going in. So you have less chance of the rear en stepping out entering corners. Then you can run slightly more front grip and still have good balance and added steering.
Ah thanks for this info Julius. I have just bought the set and now I'm really looking forward to trying it out.
Old 09-30-2004 | 06:49 AM
  #16650
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: New Mega's
If you make the diameter bigger you couldnt mesh both 1st and 2nd gear at the same time.
It's the combination of the two that seems to give problems. The 61 has it's teeth clesest together and that gives problems with the meshing with the wide open teeth of the 16.
Actually we'd rather make the 16t smaller in diameter as it would make the teeth a better shape. Unfortunately then you cnat make it fit over the bearing anymore....
This now makes sense. I've tried the 17-61 without problems at all and after this weekend's race (errr, maybe kicking Mark's a$$ ) I'm going to try the 16-60 combo.
