Serpent 710
#9138
Originally posted by Pyramid
Yes it is
Yes it is
#9142
Originally posted by markp27
Seem to remember being recommended to buy one from someone else
Well, I was still ignorant then !
How would the tweak be truer? If I'm going to do the lifting method, then any tweak will reveal itself within that process. Using the MIP would surely just mean that I'm closer to having no tweak when I start off?
It will be "truer" in the sense that the front suspension will not affect the rear suspension and thus screwing it up. What may seem to be incorrect tweak in the rear will be made correct because of the front suspension.
Hasn't Dark Lord Julius not mention this to you already?
#9144
Dee does nothing - you guessed rightly, he is a dream researcher. Of course he plots constantly the overthrow of the world - but sleep and 710 always get between him and his world domination plan
Me? I'm fine this morning - feel good after my ride into work.
What's wrong with you? What are you made of?
#9145
Originally posted by Voodo_Magic
How often do you guys rebuild your shocks i seem to be doing this before every race meet?
i have one shock on the rear which always seems to be softer that the rest if i leave for a week or so i have checked it for leaks and the little holes on the piston seem to be the same as the others is this usuall?
P.S For 'D' i have run the new rear diff now for about 4 tanks and it has fallen to bits! it started with the 3 pins that hold the adjuster to the diff coming out all at one then diff moves from side to side because it seems to thin! Going back to the standard "No frills" diff maybe a bit rougher to turn but at least i know it will do the job!
#9146
Also I can get one hours training in with the bike through the forest, which helps wake me up
Work: mobile phone design - sw side.
Instead of having a Nokia or an Ericsson, imagine having Futaba, KO or Sanwa mobile phones !
#9148
How often do you guys rebuild your shocks i seem to be doing this before every race meet? i have one shock on the rear which always seems to be softer that the rest if i leave for a week or so i have checked it for leaks and the little holes on the piston seem to be the same as the others is this usuall?
Ummm, thanks for the valuable feedback.
I don't think I've seen anybody here using it yet...
#9149
Originally posted by jfc_tech
D and me are at the same time zone...now is 1:42pm 29 April 2004...still stuck in the office and still not yet lunch. and D already sleeping
....lucky guy.
....lucky guy.
#9150
Originally posted by PSI Racing
SER802136 Aluminum Radio Plate Bracket
SER802155 Aluminum Middle Shaft Bracket
SER802241 Aluminum Anti-roll Bar Levers
SER802552 One Piece Engine mounts
SER802830 Setup Wheels
Just woke up !
