Serpent 710
Old 05-09-2004 | 08:30 AM
  #9886
crashed_1's Avatar
Default Re: Thrustbearing after run.
Originally posted by markp27
Here is my thrust breaing after driving today - looks intact but most of the grease is migrated from the bearing It needs a clean and re-grease for saftey's sake.
Cheers, Mark
Mark, if you're using Mugen Super Grease on your thrust bearings, they'll probably last you a good 3 weekends of bashing before a regrease is needed. These grease are great for the diff balls too.
crashed_1 is offline
Old 05-09-2004 | 08:31 AM
  #9887
Picard's Avatar
Originally posted by Taylor-Racing
"schumacher grease" - must be quality German grease, is it?
The same grease I used with the R12, and it has been fine
Picard is offline
Old 05-09-2004 | 08:37 AM
  #9888
Taylor-Racing's Avatar
Yep, that's the one - I previously used a lighter grease and my thrust bearing broke. I should have checked it better than I did, but with the Mugen grease it should hold longer - just in case you forget to check (Part number is B0308 - in case you need it).
Your bearing looks fine. We use a Moly based 1:1 engine assembly lube - it's like a thin grease if that makes any sense.
It does get thrown out but there always seems to be some left on the ball race and we've never blown one. I'll have to get some Mugen grease, though, thanks.
Taylor-Racing is offline
Old 05-09-2004 | 08:39 AM
  #9889
Should have used it on the R12 front arms, eh.
Just joking.
Old 05-09-2004 | 08:40 AM
  #9890
markp27's Avatar
Actually the Schumacher company is British doesn't sound very British, though
markp27 is offline
  #9891
Picard's Avatar
Just joking.
Picard is offline
Old 05-09-2004 | 08:41 AM
  #9892
Picard's Avatar
Yes you are on the money mark
Picard is offline
Old 05-09-2004 | 08:43 AM
  #9893
markp27's Avatar
Default Re: Re: Thrustbearing after run.
Hey, crashed_1 old budy! How you doing - god!!! What is that for an Avatar!!!!!!!!!!!!!!!!! I feel ill
I'm just a bit paranoid until I get some spare thrust bearings - after I blew mine yesterday, a friend kindly offered me one of his from his TC3 Nitro - the hole measured 4.4mm in the carrier so close yet so far
Has D used his Mazda shell yet?
markp27 is offline
Old 05-09-2004 | 08:46 AM
  #9894
markp27's Avatar
Wilst discussing offset rims, I'm using some 1mm spacers in the back wheels. This means I can make the track width 1mm shorter either side and thus lessen the risk of a pivot ball being ripped out As I mention in the FAQ, though, the narrower the track, the less upwards suspension travel you get - but as I'm running 200mm with the 2x1mm spacers, then I still have plenty of uptravel
markp27 is offline
Old 05-09-2004 | 08:48 AM
  #9895
OK, but what is "specified" for the 710?
Zero offset?
Old 05-09-2004 | 09:01 AM
  #9896
markp27's Avatar
Zero offset?
Yeah, the normal Serpent rims are 0 offset.
markp27 is offline
Old 05-09-2004 | 09:08 AM
  #9897
Cheers Mark.
Old 05-09-2004 | 09:11 AM
  #9898
crashed_1's Avatar
Default Re: Re: Re: Thrustbearing after run.
Makes me dizzy too...
A thrust bearing from a NTC3? Better not let D see this man...he'll go hysterical.
Has D used his shell?...He was smokin our local track with it... He was having some problems with rear traction lately. Had a bouncy rear end and found the outdrives on the rear badly eaten up by the doggy bones. The rear suspension/wheels tend to move up on acceleration.(More apparent on a starter box) It happened to mine too but managed to cure it with a set of new outdrives.
Old 05-09-2004 | 09:33 AM
  #9899
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: 200mm International at Heemstede
W-W story? You're forgetting Sow&Steady how stupid I am - which W-W story? Not the Wifey thing is it?
Yeap .. Wifey-Work thing(s). Anyway, glad to hear that you managed to drift! Now, if I only could find those RC Drifting videos I downloaded ages ago ... could then post them on 3Hobby!
I too decided to go and have a look at the track. Luckily I didn't bring the car(s), the BRCA 1:10 Electric Nationals was on! Track slightly damp but those guys were flying regardless! Now I need to go figure how to download the short video I captured onto the PC.
Sow&Steady is offline
Old 05-09-2004 | 09:38 AM
  #9900
markp27's Avatar
Cheers Mark.
No problems, matey!
markp27 is offline
