Serpent 710
Back to 710...
I have 2 questions for you guys (and girls if any)
1. I am in the part installing the 2 speed, Is there anything that I should be careful or know about, Does any one have any tips that can help.
2. Where did you guys install the on/off switch to your reciever?
Originally posted by Blue Sky
rwisejr, what synthesized units are you using with your 3PK? I thought they're not out yet.
I am currently using the spectra module from my hitec transmitter and the novak xxtra receiver.
Originally posted by markp27
Hi PSI,
Rene made a lot of explinations in his feedback - take a look here:
http://www.mytsn.com/forums/forum.as...2478&pid=10094
Wonder who the guy asking all the questions was - seems kind of familar
Hi PSI,
Is that "D's" real name?
Maybe we might finally uncover the man behind the mask.
Guy's we can drop the Hudy thing now - he's gone for good!
Anyway back to the #1 car on this thread!
I had success with a 16/61 gear combo this past weekend thanks to Master D's tip with a tighter gear mesh. I ran about 5-6 tanks through and notice no wear on the spur gear! D was right about the mesh will be tight at first then loosen up after run......Thanks!
Is 1mm seems the amount to grind away from the engine mount legs?
Good to know it worked for you. How is it going with the engine?
Having fun smoking the competition?
Disaster at the track tonight whilst I was testing my 2106 - somehow my crystal came out of my reciever - car went wild - full throttle across the track into the fence
*ouch*
bent the front part of the chassis up and it seems like the rx unit has died
hope the motor is ok, as it was on full revs for about 20 seconds
*ouch*
Strange that the controller did not go into fail safe mode.
A same incident happened to a friend of mine at our local track. The crystal on the receiver loosened out but the car went into fail safe mode and the throttle / brake servo was locked. That was on the 3PK. But I would gather that it would work the same on the 3PJ that you're using. Are you by any chance using Futaba receivers? I thought I remember you mention that you're using something else for the receiver... Perhaps that's why the fail safe did not kick in or supported...
Oh man - I'll have to see if I can rescue the chassis some how - it's the 705s 4mm one, so maybe I can bend it back into shape. It's only the very end which is bent up. Are these things fixable?
If the bend is somewhere in the middle part where the front bulkhead is screwed and mounted, there is a chance that the front part will be tweak.
, put it out here in the thread. Are you afraid that it will be copied and pasted?
