Old 02-04-2004, 08:17 PM   #3886
Originally posted by InitialD
Thanks for the tip GoldFinger. It looks like a little tedious. Besides making the diff very smooth with no oil and grease inside, what other advantages does the tip / mod you mentioned do to your current diff?
I'm actually very pleased with the current diff I'm having. Still very smooth and no gritty feeling.
- Very easy to drive, I can put very consistant (160) laps inside .7 seconds.
- Hard braking is never been easier.
- No more right pull (from stanstill)
- More confident
GoldFinger is offline   Reply With Quote
Old 02-04-2004, 08:35 PM   #3887
clmbia45's Avatar
Originally posted by cyba888
How come I never thought of that! (doh!)
Well its moves up and down fine but when I lift it up it doesnt frop down by itself. So I guess it doesnt move freely as it should be. I did loosen the 4 screws on top that holds the sway bar down but it still stays up, it helped a bit. I dont think it has anything to do with the screws. Should I put some kind of grease on it or is there something inside that gap I dont know about
The reason I brought this up, is I found a problem when I built mine. The center of the anti-roll bar has an upside U shaped bend which rides up in the hole in the carbon fiber. If you look at the under side of the carbon fiber plate, after you have run the car you may see where it is wearing on the under-sides of the hole in the carbon fiber. I had to shave off a 45 degree bevel on both sides to get the anti-roll bar to move freely in either direction.
clmbia45 is offline   Reply With Quote
Old 02-04-2004, 09:17 PM   #3888
JustRace's Avatar
Default Tornado Fuel Filter
But still, I'm still using the small external fuel filter made by Tornado.
What's inside this Tornado filter? Is it just a fine mesh or something similar to the brass piece in most fuel tanks?
JustRace is offline   Reply With Quote
Old 02-04-2004, 09:18 PM   #3889
cyba888's Avatar
Do you have a picture as to how much you shaved the anti-roll bar? My car is spanking new with only 4 break in tanks so far
Do you think after some more run in time with my car the anti-roll bar will move more freely on its own? I dont know if I should raise the bar higher on one side or to shave the bevel
Im leaning more towards shaving it, I done like it when things are uneven
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 02-04-2004, 09:24 PM   #3890
Pyramid's Avatar
Pyramid is offline   Reply With Quote
Old 02-04-2004, 09:35 PM   #3891
clmbia45's Avatar
I didn't shave the roll bar. I shaved (beveled) the underside of the carbon fiber plate. The up-side down, U shaped part of the bar, moves foreward and aft as you raise and lower the ends of the bar. This binds on the under edge of the carbon fiber plate, on each side of the hole, on my car, and it sounds like it does on yours too. About a 45 degree bevel relieved this. Sorry I can't take a pic-- I'm all packed up for the Winter Nats.
I do believe this will wear in in time.
Old 02-04-2004, 09:42 PM   #3892
cyba888's Avatar
Cool... will check it when I get home to see which part of the carbon fiber needs to be shaved. Did you use a dremel or sandpaper?
Good luck at the Winter Nats, you will be racing?
Futaba 4PX
Old 02-04-2004, 09:54 PM   #3893
clmbia45's Avatar
Dremel
Old 02-04-2004, 09:56 PM   #3894
clmbia45's Avatar
Dremel
Sorry, yes, Sedan. My goal is to do better than last year, and hopefully not last.
Old 02-04-2004, 10:04 PM   #3895
Sow&Steady's Avatar
Originally posted by Picard
S&S
Dusty and low grip sounds exactly like our track, it is technical.
I usually drive with a oneway, what difference will a locked oneway have besides giving me more brake? Will I lose some turn into corners?
Picard, in my opinion, a locked one-way should not be used just to get more brakes alone.
I prefer to look at the track layout first: if its highly technical with a lot of last minute braking required then I don't have a choice but use a solid front (at least until the front diff becomes available anyway). If the thrack is a combo of sweeping corners as well as braking then I'll most likely use either depending on my driving confidence on the day.
On some configuration, a solid front can give a tremendous out-corner on-power advantage apart from braking. This though you need to balance with tyre wear, fuel economy and available grip.
Given the chance I prefer to race with a front one-way and solid rear though!
Sow&Steady is offline   Reply With Quote
Old 02-04-2004, 10:07 PM   #3896
InitialD's Avatar
Default Re: Tornado Fuel Filter
It is a simple fine mesh of netting.
Old 02-04-2004, 10:08 PM   #3897
InitialD's Avatar
Old 02-04-2004, 10:26 PM   #3898
InitialD's Avatar
When you say link, do you mean the rod with the ball cup or adjust it where it attaches to the sway bar(farther in)?
Step 3.12 on page 14 of the 710 manual suggest to use 48 mm as the connecting rod length for the rear sway bar.
Adjust this length accordingly to adjust tweak.
Old 02-04-2004, 10:37 PM   #3899
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
I LOST MY LITTLE 710 BOOK!!!
Damn how can i get another copy, anyone?
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 02-04-2004, 10:48 PM   #3900
Sow&Steady's Avatar
Ah! Easy! Go out and buy another 710!!!
