Serpent 710
Originally posted by pelos
I have been living so long with the nightmare of ruining my wonderful NSR12S3... now is happened.
Maybe I used a too hot plug (6TC with 18C temp and 16%nitro) or maybe I was too lean (about 4 1/4 turn out HSN).
The plug broke and filament scratched piston side. Top of piston is also sandblasted. See pics
The motor run about 8/9 liter.
What can I do?
What can I do?
for you.If it was my engine, I will clean it off, rebuild it and sell it cheap.
Coz in my opinion, it will not recover even P/S+rod is new. The con-rod(big end) and the bearing is suffer from lots a vibration.
What can I do?
What can I do?
Originally posted by GoldFinger
Feeling sorry
for you.
Feeling sorry
Originally posted by BaxterC
OW... I feel for you too, what fuel were you using (% Nitro) and what heat plug were you using?
Originally posted by InitialD
Titanium does not have a good wear characteristic. We need HUDY Spring steel.
High performance parts does not last usually.If I want the car light then that's the "price" I'll have to pay. I'm not expecting the Ti shafts to allow faster rotation since we know that the shafts are too small in diameter to make a difference to the rotational mass.
Of course, like you said, if Serpent comes out with hollow shafts from Hudy Spring Steel, that would be perfect! Light AND long lasting.
This last statement somehow does not sound right for a business
, Serpent has to make money somehow too.
The other thing I'm hoping that will come to those who wait is the KHM .12 engine!
What can I do?
What can I do?
Just get the P/S replaced...and be a little more careful with the tune...
Originally posted by PSI Racing
$140 isn't too bad.
I would like to try one out before investing on one though.
$140 isn't too bad.
Once I tried the tool, I was immediately in love with it.
Are you planning to get one?
Yup, you're right, that is why F1 cars literally lasts only 1 weekend's race.
Just like what crashed_1 suggested, perhaps you could put new piston / sleeve in together with a new conrod. How are the other parts like the bearing?
Anyway P/S + conrod + rear bearing is 160 USD at mushroom, I will think over, don't know if it is worth since for 260 USD I can have a new engine...
BTW how do you take the rear bearing out? Heat gun and ...?
Front bearing is ok, rear one (I mean the one inside the crankshaft) has something inside: you can feel it sometimes turning by hand. But may be I can take it away since you do not feel it constantly.
