Old 05-27-2004, 07:15 PM   #11506
InitialD's Avatar
Default Re: Re: Re: Mazda 6 Wing
Originally posted by PSI Racing
I'm not talking about the fins that you could add on.
I'm talking about the holes that are cut out in the picture.
It's sort of hard to see it, but it's in the middle of the wing.
Hookay ! Thanks for the pic. It's crystal clear now and like what you said, I did not try it out yet. In fact I never knew that you could do that to the rear wing to aid performance. Will try that out too. Thanks again.
Old 05-27-2004, 07:20 PM   #11507
InitialD's Avatar
Default Re: Clutch
Has anyone tried the yellow shoe with the modified flyweights and the stock spring?
I've modded my flyweight to sit in the middle of the flyweight pins AS WELL as putting 2 grub screws (M3x4) on each flyweight as per Goldfinger's recommendations. The yellow shoes have still not arrived yet. I'll be trying with the stock and harder spring.
Old 05-27-2004, 07:22 PM   #11508
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Clutch
Originally posted by Sow&Steady
You got it buddy, especially the Ti shafts!
Titanium does not have a good wear characteristic. We need HUDY Spring steel.
Old 05-27-2004, 07:24 PM   #11509
InitialD's Avatar
Default Re: Re: will this servo fit in my 710?
Originally posted by InitialD
They should fit ! Team Serpent in Holland uses them predominantly.
Ooophs, sorry. I think they predominantly use analog versions of the Sanwa servos. But I believe the digital ones should fit too.
BTW, for those who don't know, Airtronics = Sanwa.
Old 05-27-2004, 07:29 PM   #11510
Send a message via AIM to kreidel
Default Short track
Have you raced any short tracks lately IntialD? Anything more you can share?
kreidel is offline   Reply With Quote
Old 05-27-2004, 07:41 PM   #11511
PSI Racing's Avatar
Default Re: Re: Re: Re: Mazda 6 Wing
I think I'll send an email to Protoform to see how those holes aid in the performance of the body.
PSI Racing is offline   Reply With Quote
Old 05-27-2004, 07:48 PM   #11512
InitialD's Avatar
Default Re: Short track
kriedel, I just posted the setup below for Sow&Steady. This is for front and rear ball diffs. Have you got to try the front ball diff yet? Or are you still sticking with the front solid axle?
Suspension geometry Front:
Downstops: -1 mm
Set-up ride height: 6 mm (Actual ride height !)
Camber Left: -1.5 degree
Camber Right: -1.5 degree
Track-width: 198 mm
Toe-in: -1 degree (Toe-out)
Caster setting (mm in front): 2 mm
Roll-center position upper arm (mm): 0 mm under (highest RC)
Upstop (mm): None
Suspension geometry Rear:
Downstops: 8 mm
Set-up ride height: 7 mm (Actual ride height !)
Camber Left: -4 degree
Camber Right: -3.5 degree
Toe-in: +2 degree
Track-width: 198 mm
Roll-center position upper: UTI
Roll-center position lower: LT
DRS arm position (low-mid-up): Mid
Shockabsorbers Front:
Springs: Yellow
Oil: 40W
Holes: 4x1.2mm
Cilinder type: composite
Shock-tower position: 2nd hole
Shockabsorbers Rear:
Springs: Yellow
Oil: 40W
Holes: 4x1.2mm
Shock-tower position: 1st hole
Lower shock position: Outside
Anti-roll bar front:
Thickness: Standard
Position: 90 degree (hardest)
Anti-roll bar rear:
Thickness: Standard
Position: 0 mm from end
Position on lower arm: Inside
Tires Front:
Make: SpeedMind Dishwheels
Hardness Left: 42 shore
Hardness Right: 42 shore
Diameter: 63 mm
Wear in 5 min. Left:
Wear in 5 min. Right:
Tires Rear:
Diameter: 63 mm
Transmission:
Pinion 1st: 16T
Pinion 2nd: 21T
Gear 1st: 61T
Gear 2nd: 57T
Front axle:
Type: Ball Diff
Diff. setting: Medium (when hot)
Rear axle:
Type: Ball Diff
Diff. setting: Soft (when hot)
Aerodynamics:
Body: Mazda 6
Wing: Standard
Gurney strip: -
Engine and pipe:
Engine: NovaMax
Version: P5
Head shims: 0.4mm
Glowplug: 6TC
Pipe: RDLogic .15 (61600)
Header: Novarossi 40603
Length: 88 mm
Fuel: 25% Model Technic
I tried to use 5x1.2 mm shock pistons with 50wt oil all around with front yellow and rear red. The car felt skatey a little but very nice on power steering. Should be good on large tracks.
You would also notice that I tried 42 shore front and rear tires. I was just testing to see the limit of how much the car would still be able to stick on the track. Softer tires like 37 shore all around should work much better.
You could also use the Serpent 30wt oil and open 4 or 5 holes with yellow springs all around. I found it works good if you have a technical track.
Old 05-27-2004, 09:03 PM   #11513
Bro, lately I found this as a rule of thumb :
- With soft dampening(/fast acting_low visco), the car handles better with lower shore (35,37)
- With hard dampening(slow_high visco), the car is even better when you raising the tire shore (42 is max I ever try).
"Better" here is not always mean faster lap tomes.
I do not know the logic behind it. Before, I thought it was only something wrong with my car.
But it became a crystal clear at the GQ Cup event when everybody can not change their shore.
Any comment guys ??
GoldFinger is offline   Reply With Quote
Old 05-27-2004, 09:06 PM   #11514
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Like I mentioned before, the FW05R car is very suited for small tight tracks. But on big tracks, you need to modify their gearing properly. Else, you get a toast engine.
If you want the same kind of acceleration as the stock geared FW05R (1st gear FDR of 7.47) with 62 mm tires, you need to gear the 710 with 16/61 (1st gear FDR of 7.15) with a tire diameter of 59 mm to get the same kind of launch.
As for the 2nd speed on the 710, use 21/57 (FDR = 5.09) with 59 mm tire diameter to match with the FW05R's FDR of 5.44 with 62 mm tires if you think that the top end of the FW05R is suited for your track.
amazing "d" you sure know your stuff
Old 05-27-2004, 09:15 PM   #11515
MrChan's Avatar
Send a message via ICQ to MrChan
Clutch Setting is also a big factor .
MrChan is offline   Reply With Quote
Old 05-27-2004, 09:19 PM   #11516
Dont even think to challenge him on that stuff
Old 05-27-2004, 09:23 PM   #11517
Super Moderator
Marcos.J's Avatar
"INITIAL D"
Old 05-27-2004, 09:26 PM   #11518
Marcos.. I meant "His" stuff
Old 05-27-2004, 10:33 PM   #11519
SupermaxxRich's Avatar
How are you liking the front ball diff "D"??? I'm just about to install mine this weekend along with trying out some 40 shore GQ wheels.. Did you add any fuel tubing in the front to help keep the dog bones from coming out? What kind of tire wear are you getting with that setup posted above? I'm going to run the tires straight out of the box and see how they wear and if the car changes much in handling from when the tires are new till when there worn right down. Would you change anything on your setup posted above "D" if I were to run the tires at full size?? Thanks in advance.
SupermaxxRich is offline   Reply With Quote
Old 05-27-2004, 11:10 PM   #11520
InitialD's Avatar
I quite like the front ball diff. Well, it's a diff and it's easy to maintain and adjust externally. I don't add fuel tubing in the front outdrives. I just the front trackwidth to 197 mm (oophs, that reminds me... I need to edit the recent setup I posted) and it never comes out. Of course if you clip the curb or boards real bad, it will come off. No two ways about it.
As I'm using hard front and rear tires (42 shore), the rear still wears a little more than the rear. Say about 1 to 2 mm more. With the solid front axle, I could get the front and rear to wear about the same.
Anyway, when you use a different tire size, make sure you check your ride height again by playing around and turning the shock collar. When you adjust the ride height, make sure you check the wheel cambers again. Also, you would need to compensate on the droop settings when you adjust ride height. The amount of chassis uptravel from your ride height (taken as datum / zero level) till the tires lift off the ground should be the same when you use small or big tires. To get the same amount of this chassis uptravel, you need to adjust the droop screws.
For example, if you have 63 mm tires and use -1 and +8 for droop in front and rear, changing to 65 mm tires would give you an additional 1 mm of chassis uptravel (i.e. [65-63]/2=1). So to limit it back to original chassis uptravel as if your car had 63 mm tires, you would need to set your droop screws to 0 (i.e. -1 + 1) and +9 (i.e. +8 + 1) respectively for the front and rear when you use 65 mm tires.
Taking the example above, since very little droop was changed going from 63 mm to 65 mm tires, you could still stick with the same original droop settings. More so since the car has a wider sweatspot. Good luck.
