Serpent 710
Originally posted by InitialD
Yup. I hear our competitors are also using that book to solve their car handling problems !
Serpent should have used Parsel tongue as their language
(see Harry Potter: it's the Snake language!!!)
Well, there is no minimum. From what I read, Julius mentioned that 4 mm was the sweat spot ! You can try 3 mm or 5 mm. Perhaps it will or will not be better.
Oh man, and I can't cut the screw down - the screw is too long for a 4mm spacer
If that's hell, I want to go to !
Let's hope at the end of the day they give you 3 engines then or charge you only for 1 engine instead of 2.
Don't know what you're talking about *cough* tyre truer *cough*
Originally posted by GoldFinger
When you start using drag brake, spring on the brake linkage instead of fuel tubing is smoother.
You're just going to have to sin then, aren't you
Use a shorter M4 screw. I can't remember off my head but the stock one was like M4x20. I think M4x16 would do the trick.
What do you mean bro? Instead of the usual fuel tubing on the front of the brake linkage where the plastic knob is, you replace it with a spring?
If you wanted to brake hard, then it would be very difficult to stop the car. I guess not if you're using oneway.
what do you have now, profoxcg
no car for a few days. then ill get an mtx3 or a prospec. For some reason I am skeptical about paying the extra $180+ for the prospec
Hi I have two questions in reference to my NOVA MAX 5P:
First: I am interested in getting a spare CONROD but due that this is a modify engine I don’t now if I can use the regular part from NOVAROSSI NS12 S5
Second: What is the effect in changing the Head shim from .3 to .4
Originally posted by rcpanama
As per the manual you are correct but I do like it this way, you can check this side from Glenn Cauley and check some comments on this
http://www.mytsn.com/forums/forum.a...62&pid=9569
Jose
Jose
You might want to reconsider the throttle linkage.
With the fuel tubing on the carb side, the carb will indeed close more quickly. However, when you brake the servo will strain against the fuel tubing. This is NOT good for the servo.
Hi Glen yes I did change yesterday the fuel tubing change it to a spring, the i4C Voltage monitor shows that with the spring the consumption is down when I hit the brake.
Yes, you can use the conrod from the NS12 engine. In fact, all Novarossi .12 engines use the same conrod. Part number is NRS-07601.
You gain a little in the top end at the expense of a little bottom end. Temperature should drop a little due to less compression.
