Old 05-10-2004, 08:03 PM   #10036
Suspended
hudy's Avatar
im sorry but the new kyosho touring car will be the car to beat I was going to buy this car but the V one RRR looks very good
hudy is offline   Reply With Quote
Old 05-10-2004, 08:03 PM   #10037
InitialD's Avatar
Originally posted by KevinS
Does anyone know the partnumber for the 2-5 hole shock pistons? Or are they an update with the same part# as the 1-4 hole pistons?
Yup, as Mark mentioned, they are the same number. Running change I guess.
Old 05-10-2004, 08:05 PM   #10038
InitialD's Avatar
Don't be sorry... Should be a good car. Wait a few months and give it a go. Let us know.
Old 05-10-2004, 08:08 PM   #10039
InitialD's Avatar
Default Re: Been to the track again!
Originally posted by markp27
I had to adjust the changing point of the second gear a couple of times - still don't think I've got it perfect, but its a lot better. And the engine definately needs to be tuned better - here I still have a lot to learn!
Did you fix the 2 speed shoe spacing between bell housing? Perhaps the LSN is still rich.
Measuring the tyres, I found that left rear was 62.19mm, left front 62.18mm, right front 62.17mm and right rear 62.19mm!!!! WOW!!! Each tyre was trued to 63mm before the 4 tank run and they wore exactly the same amount front and back - all using only 0.8mm for the 4 tanks pretty good!
Cool.
Old 05-10-2004, 08:09 PM   #10040
Suspended
hudy's Avatar
initial D will you be hoping on a new bandwagon now
Old 05-10-2004, 08:12 PM   #10041
InitialD's Avatar
Originally posted by Profoxcg
3 racing pulleys
I would not use that... The drive train is already very free as it is. Belts don't come cheap.
3 racing CVS
I have seen them. They are so so. They still do break on hard impact. I would think they are pretty reasonable. Not excellent. I would wait for the Serpent one...
BTW, does anyone else have to HAMMER the pins in and out of the one way axle? I think I am going to drill mine larger, but what are the chances of damaging the one way bearing?
Yes, I needed to do that. It was initially tight. I use a plastic hammer tip and a 2 mm allen to tap the pins into the oneway. After a while of driving, I found the pins to be just right. No need to force it in again.
Old 05-10-2004, 08:14 PM   #10042
InitialD's Avatar
Originally posted by bigknot
How do I lower my ride-height on a Serpent Impulse Pro?
Use the shock collars. Set ride height first before setting the droop, tweak and then the camber and toe in / out. That is because the shock settings affect the camber.
Old 05-10-2004, 08:15 PM   #10043
Send a message via AIM to Profoxcg
I found the 3racing carbon front bumper plate very usefull if you like to take off your bumper when setting droop.
I noticed that as an option. is it a good fit?
What new kyosho car?
Profoxcg is offline   Reply With Quote
Old 05-10-2004, 08:16 PM   #10044
alright then, ill just leave the pins there for a bit then.
Old 05-10-2004, 08:17 PM   #10045
InitialD's Avatar
I'm already on a new bandwagon, thank you.
Old 05-10-2004, 08:20 PM   #10046
so what new kyosho car?
Old 05-10-2004, 08:21 PM   #10047
Pyramid's Avatar
I believe I need to cut my alum post that hold lower and upper plate by 1.25mm if not mistaken (might want to ask D, he remember everything ) in order to have the PERFECT fit.
Ok.. got to go to Airport now.. dont post too much D, I find it hard to catch up this threads..
Pyramid is offline   Reply With Quote
Old 05-10-2004, 08:22 PM   #10048
InitialD's Avatar
Default Re: please correct me, I am having an hard time getting this into my head..
roll out numbers,...
is smaller better? can someone explain please?
Smaller gives you smaller top speed ! Tire rollout is just that. Smaller also gives you better acceleration.
62mm x pi (3.14) / FDR of the gear
correct?
Yup. 62 mm is the tire diameter.
and also the smalled the FDR means the more top speed but not necessarily the best accel
Yup.
Old 05-10-2004, 08:26 PM   #10049
InitialD's Avatar
Default Re: setting the front anti roll bar
Do you guys take your bumpers off?
No need to take the front bumper off ! Just use a 2mm allen and fit it in on the end of the sway bars. The end of the blade cup / ball front sway bars have a groove that fits a 2 mm allen. Turn it to your liking. Make sure the grub screw that holds the front sway bars are just tight enough that it permits you to turn it. Not too loose though.
Old 05-10-2004, 08:26 PM   #10050
uh? what do you mean lol ur confusing me now,
a car with a larger number for tire rollout will move more down a line with one revolution of the engine... right? so therefore, larger values are better? or not?
this is what Iam consused on
