Serpent 710
Originally posted by InitialD
If you're serious in racing, then having two engines is good. But what I'm puzzled is why do you think race bred engines don't last long? Are you expecting them to perform well above others and at the same time last a lifetime?
Suspended
I AM ABOUT TO BUILD MY
710 BUT THE ENGINE I HAVE IS A RB X12,IS THIS ENGINE ANY GOOD?
On this Centax clutch do you have to tear the pinion gears off to change the engagement, or is it externally adjustable?
Re: I AM ABOUT TO BUILD MY
Suspended
Re: Re: I AM ABOUT TO BUILD MY
The RB X12 while being older than the latest RB V12 or Novarossi NS12 engines is still a decent engine no doubt.
Have you seen containner accident in Malaysia D?
I don't know if you ever need to do that on the crankcase... Marketing gimmick? Perhaps. But has anybody seen a crankcase breaking because of the high performance of the engine? I'm not referring to crankcase breaking due to impact.
But I do agree that coatings on the crankshaft and crank pin is definitely a plus. KHM does that also I believe.
how many of you guys are running the stock plastic shock bodies on your 710
Im waiting for my LHS to have them in stock because I dont like the idea of my shock bodies being plastic
where can I buy these online
Suspended
NO,TELL US ABOUT IT
Originally posted by speedy100
i have been using the plastic shock body since my NT, 950 and 710 but have not had any problem so far. they have the aluminum shock body but i found no difference.......
I am confused as to how you turn your electronics off when the 710 has no place to install the on and off switch how do you guys turn your electronics on and off do you put the battery connector on your receiver and then un plug it
The rb concept coating in those crank pin has significally improved the wear.
