Serpent 710
Originally posted by FW05R
how many of you guys are running the stock plastic shock bodies on your 710
If you have aluminum shocks, while it may not break during an impact, something else might break.
no problems at all
no problems at all
I am confused as to how you turn your electronics off when the 710 has no place to install the on and off switch how do you guys turn your electronics on and off do you put the battery connector on your receiver and then un plug it
What we use is a servo extender. This servo extender connects to the receiver and the other end of the servo extender connects to the receiver battery pack. Just unplug the receiver battery connector from the servo extender plug to switch off and plug it to switch on.
This is better than plugging the battery directly into the receiver as it helps prevent the receiver pins from becoming damaged. Also, if you wrap the receiver up in balloons etc to protect it from the elements and general dirt/fuel then it becomes a necessity.
If you really want you can just drill a couple of holes somewhere on the radio plate and mount a switch.
Originally posted by InitialD
How many times do we need to repeat this?
What kind of problems are you expecting? Perhaps there's something which we are not aware of...
the problem I am expecting from the composite shock bodies is that the thread will eventually wear out from adjusting the shock tension
I was not aware of this "D" sorry if I angered you
Originally posted by Palmaris Europe
D, you dont play the game right. You have a special lead with little heli rotorblades. And I thought I was lazy
Nope. Anything to do with RC?
...since `Redsand` just about to have a heart attack, picture has been deleted ...so there will be more Serpent users in Indonesia (j/k)
Stripping the thread by adjusting the shock tension with the shock collars will never happen.
You only need to be careful when you lock the shock cap onto the shock body as per step 4.7 on page 18 of the assembly manual.
What I do is I would turn the shock cap CCW on the top of the shock body (after filling the shock oil) until I feel a certain "click". This would indicate that you got the start of the threading groove on the shock body. Then start to turn down and tighten the shock cap CW.
FP-300202 Switch Harnes W/charg lead
FP-302312 Futaba, BattExt.Cord,Thick
why would someone post that kinda pic ? THAT IS SICK.
