Old 05-27-2004, 11:14 PM   #11521
InitialD's Avatar
Originally posted by MrChan
Clutch Setting is also a big factor .
Oh yes ! Taking into account both being equal of course.
Old 05-27-2004, 11:22 PM   #11522
InitialD's Avatar
Originally posted by GoldFinger
I do not know the logic behind it. Before, I thought it was only something wrong with my car.
But it became a crystal clear at the GQ Cup event when everybody can not change their shore.
Don't know the logic in your findings. But what I found is that the 4x1.2 mm with 40 wt oil (or 5x1.2 mm holes with 50wt oil which is slightly harder) is somewhat the same feeling as using 30wt oil with 4 or 5x1 mm holes.
Also what I found is that harder tire shores have better and more consistant SIDE BITE as compared to softer shores with the same set of shocks. For high speed tracks, I would use harder shores if permitted because they handle high speed sweepers better. Softer tires would hook the car and the feeling is not too consistant on high speed tracks. Technical tracks where you need the car to behave and react quickly, softer tires are better. Of course, these are just my findings...
Old 05-27-2004, 11:22 PM   #11523
BaxterC's Avatar
Originally posted by Marcos.S710
"INITIAL D"
I agree...
Dee
BaxterC is offline   Reply With Quote
Old 05-27-2004, 11:34 PM   #11524
FW-05RR's Avatar
initial d what car are you currently running and why
you seem to be very knowledgeable about every factor in this hobby so knowing what u drive and why will tell me alot of things
FW-05RR is offline   Reply With Quote
Old 05-27-2004, 11:44 PM   #11525
InitialD's Avatar
I drive the 710 and I'll be very biased if I tell you why I like the car.
Actually, driving the 710 or any Serpent car does not make you knowledgeable. But I do not deny that driving the Serpent has sparked my interest to know more about the hobby and designs of other cars in particular. I find learning new things fun and at the same time challenging and very fulfilling. More so when you do it as a hobby. It is very satisfying to apply what you know against what you do on the track and see their results coming out the same.
Old 05-27-2004, 11:55 PM   #11526
FW-05RR's Avatar
wow initial d what car did you drive before the 710
Old 05-27-2004, 11:58 PM   #11527
Yes, could be.
But I still think that piston hole or diameter were dictating the piston speed And the visco is purely resistant weight.
Also what I found is that harder tire shores have better and more consistant SIDE BITE as compared to softer shores with the same set of shocks. For high speed tracks, I would use harder shores if permitted because they handle high speed sweepers better. Softer tires would hook the car and the feeling is not too consistant on high speed tracks. Technical tracks where the car to behave and react quickly, softer tires are better. Of course, these are just my findings...
I got 1 question that keep bothering me, with same setup do you
need to use 1 step harder tire shore for final run?
Sunny day (50-60 track Temp) and cooler afternoon(40C track temp)
GoldFinger is offline   Reply With Quote
Old 05-28-2004, 12:05 AM   #11528
InitialD's Avatar
Serpents too ! My first was an Impulse PRO. Then the Serpent 705.
Old 05-28-2004, 12:11 AM   #11529
InitialD's Avatar
Yes, could be.
I guess so. That's why Julius say that they are different although the "feel" the same.
I got 1 question that keep bothering me, with same setup do you need to use 1 step harder tire shore for final run?
I believe most people run harder shoes in their final run because of tire wear.
Generally, I found that harder tires are also better when the track is hotter. When the track is cold, soft tires are better. Soft tires only provide marginal performance in terms of traction compared to harder ones when the track is hot.
I guess at the end of the day, you need to test the different tire compounds out on the track to determine what handles best.
Old 05-28-2004, 12:28 AM   #11530
FW-05RR's Avatar
"d" do you also drive 1/8 scale
Old 05-28-2004, 12:39 AM   #11531
InitialD's Avatar
Sorry I don't. There are very few tracks that I can drive the 1/8th scale.
Old 05-28-2004, 01:03 AM   #11532
Thanks bro.
Old 05-28-2004, 01:04 AM   #11533
Soon!
Old 05-28-2004, 01:11 AM   #11534
InitialD's Avatar
Soon!
Old 05-28-2004, 01:21 AM   #11535
pelos's Avatar
Default Sandblasted piston
I have been living so long with the nightmare of ruining my wonderful NSR12S3... now is happened.
Maybe I used a too hot plug (6TC with 18C temp and 16%nitro) or maybe I was too lean (about 4 1/4 turn out HSN).
The plug broke and filament scratched piston side. Top of piston is also sandblasted. See pics
The motor run about 8/9 liter.
What can I do?
pelos is offline   Reply With Quote
