Serpent 710
Originally posted by GoldFinger
If Im not wrong, that word is coming from Master Art.
He dont like the way alu. body react to the track temp. Hotter ambient will lower the visco.
Personally. go with aluminium body! will save your shock budget
I use them for my testing purposes instead of draining and refilling them with different shock oils.
Originally posted by Pyramid
Is the Japan tuned such as Mspeed and Kondo available at your side? how`s the pricing if any?
You can buy 2 normal Novarossi engines.
Apparently speed wise, the Max is about the same or in fact a little faster than the MSpeed. For the price, it's not so worth it.Kondo?
It's not available here but it is available there in ID?
Brandon McNally took the lead immediately with his Serpent 710 and never looked back. Starting from third grid position Brandon timed the start perfectly and was in the lead at the first turn. He never gave up the lead for the entire race. Brandon dominated the field with a 10 lap cushion at the end of the one hour A-Main. Normally this class is so close and competitive, yet Brandon averaged lapping the field every 6 minutes. Brandon’s Serpent 710 was equipped with the latest NovaMega SS-12 3 port turbo engine. The horsepower was transferred to the Ellegi six spoke wheels that provided the grip and durability for the one hour main with no tire changes. Congradulation to Brandon and his very fast Serpent 710.
Originally posted by InitialD
MSpeed?
Kondo?
MSpeed?
Originally posted by speedy100
Initial D is correct, it is not worth to get the Mspeed as their motor is not as fast as the Max or JP....most of the things from Mspeed are eyecandy only....nothing improved in the perfromance wise
Anyhow, they came up with RR12 version that I really wanted to know.. any change you guys tried that?
I thought goldfinger with 3 sets already the `max`... you just never know
Someday (believe me, soon!) when i can qualf above you, I wont let you using my spares
Originally posted by FW05R
I was reading the s710 black book from the link above me and I was thinking do you really need to mod this car this much to get it working properly or is this guy just Hardcore?
Seriously, I have not done any mods (except for the clutch) as listed on the webpage to get the car working.
