Serpent 710
Originally posted by Pyramid
I thought goldfinger with 3 sets already the `max`... you just never know
Well, those are some shock scraps that I have picked up and built over these years. So only 2 or 3 sets are new type while the others are the old type screwed on piston. All of them are also not adjustable type. Some of them I have built from the fixed type pistons. But all of them with purple O rings, red shock bladders and foam inserts.
O thank god I thought this car had all these bugs in them and you needed to do all this to get it working properly but coming from you master D im glad you replied to my post and showed me the light
aslo why did you do the clutch mod is there something wrong with the one that comes in the kit
Originally posted by FW05R
also D that engine your running the Masimo Fantini on your 710 is superv great choice
You could also get the JP FX12 engine. Very expensive too.
What do the others think about this engine? Any experience / observations? Goldfinger / Pyramid?
Originally posted by InitialD
speedy100, have you tried the MSpeed engine before?
As the name implies, the following information is only additional tips and tricks for building and modifying your S710. Some tips/tricks are cited from the Net by its respective posters or creators.
Nothings perfect, except when we "believe" it is perfect.
cool thx D so when you say "as it bites better" you mean quicker initial acceleration
also how do you quote people on these forums for example
Originally posted by Sow&Steady
Thanks.
1 mm? Hmmm ... if I look at some of the innovative designs of the rear wings on some of our friends' bodywork, 1mm seems a slither of a hair that would not make a difference
Don't get me wrong, I'm trying to encourage all of us to stick by the rules even though we all love the outlaw class
OK, I'm off to the track ... byeeee!
Thanks.
WAS THAT A SHOT AT ME??? AND MY BODS??? LOL... I WOULD NEVER BREAK THE RULES
"Da Hellion"
Originally posted by GoldFinger
I thought it was the REASON that you dont have an extra pairs on your box ?
Someday (believe me, soon!) when i can qualf above you, I wont let you using my spares
It would have been better if D is also our local racers.. I would have no need to build any shocks..
It is additional, not a hardcore or die hard modded.
It`s rude of you to point out/quote that message as it clearly stated what those `craps` all about if you read it.
25% with no shims?
Are you sure?
Good to know the car is working good for you.
25% with no shims?
Are you sure?Good to know the car is working good for you.
Yes I have no shims under the head. Thought the 25% nitro was blowing my glowplugs because of that but it seemed to work fine now
Well, it's also pretty expensive.
Just need to try to equip it with ceramic bearing
