Old 06-26-2004, 05:34 PM   #13201
Sow&Steady's Avatar
Originally posted by InitialD
I think Michael put the weight there to balance the chassis.
I have a different opnion, I think he put the weight to bring it up to the legal weight as per ROAR rules and since they have so cleverly designed the 710 as it is, the weight there also helps with the balance of the chassis.
To just put the weight there to balance the chassis is not advantageous enough ... you've seen Ray Wood's video ... the track is so rough (as well as high speed) that I think the 710 handles fine without being perfectly balanced. My 2 cents' worth.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 06-26-2004, 09:54 PM   #13202
teammpp's Avatar
Default Re: Re: Re: a water snake!!!!!
If I'm not mistaken, that's a recent photo of Paul Knapton's 710.
Yep. Hard to make out the silver with the reflection from the rain. Unfortunately I believe he was disqualified from that event after dominating and winning the A Main.
All I am saying is real petty incident.
teammpp is offline   Reply With Quote
Old 06-27-2004, 09:29 AM   #13203
InitialD's Avatar
Originally posted by KevinS
Air? No... I'm not THAT stupid... I use helium!
So with Holland through, you went head banging session the rest of the weekend?
Old 06-27-2004, 09:30 AM   #13204
InitialD's Avatar
Default Re: Re: Re: Re: a water snake!!!!!
Disqualified? How?
Well, I actually happened to browze the recent setups on mytsn. And the name of the JPG file gave the clue away. So much for the RING.
Old 06-27-2004, 12:16 PM   #13205
Well, car is built, BUT, this morning, two of my shocks was almost emty of oil. I can see under the car, that it has leaked out.
Any cure for this?
Finken is offline   Reply With Quote
Old 06-27-2004, 02:45 PM   #13206
markp27's Avatar
Send a message via ICQ to markp27
Any cure for this?
Have you got the rubber seal in the lower cap of the shock? And also make sure that the cap locked into position (i.e. you have to twist the cap clockwise to ensure that it is locked into position).
Cheers, MArk.
markp27 is offline   Reply With Quote
Old 06-28-2004, 05:14 AM   #13207
lagnaf's Avatar
Send a message via MSN to lagnaf
Default Pipe repair and protection
Hi S710 drivers!
On this weekend I have damaged my exhaust pipe from the side.
My budy has ran in to me from the side and it was my fault cause I hade a spin.
The pipe is squashed from the both sides. it is Nova Mega 2171.
Can I drive with pipe in this condition?
How can I repair that?
Has anybody done some protection around the pipe?
Any pics would be nice ...
Thanks a lot
lagnaf is offline   Reply With Quote
Old 06-28-2004, 05:23 AM   #13208
markp27's Avatar
Default Re: Pipe repair and protection
Originally posted by lagnaf
Hi S710 drivers!
Thanks a lot
I know some guys fill the exhaust with water, blocking one end, and then place it in the freezer - the expanding nature of water when it freezes pushes out the "dents". But keep a careful eye on the pipe in the freezer - don't just leave it there or else it may split.
Cheers, Mark.
PS: I've never tried this, but others guy here have.
Old 06-28-2004, 05:30 AM   #13209
lagnaf's Avatar
Default Re: Re: Pipe repair and protection
Cheers, Mark.
Thanks for this advice
Will try this today
But how can I block the water 100%?
I think the Ice pressure will push the blocade out!
Cheers, Ognjen
Old 06-28-2004, 05:43 AM   #13210
markp27's Avatar
Default Re: Re: Re: Pipe repair and protection
Will try this today
Cheers, Ognjen
I don't think you have to block the pipe 100%, just enough so the water doesn't run out before you put it in the freezer. And, like I mentioned, I believe you should leave one end open (i.e. the end which fits onto the manifold) otherwise the pressure is too high. Keep checking the pipe in the freezer often to ensure that it doesn't go too far.
Cheers, Mark.
Old 06-28-2004, 05:51 AM   #13211
lagnaf's Avatar
Default Re: Re: Re: Re: Pipe repair and protection
Cheers, Mark.
OK
Will do so!
Can you tell me what is this guy put around the exit end of the pipe? This grey stuf what is this? It should make this litlle exit pipe more stable.
Cheers, Ognjen
Old 06-28-2004, 06:17 AM   #13212
markp27's Avatar
Default Re: Re: Re: Re: Re: Pipe repair and protection
OK
Will do so!
Cheers, Ognjen
If I'm not wrong that is the Mother Serpent from Pyramid - it looks like some kind of putty around the pipe and it will certainly be to strengthen the tail pipe.
Strange that it is so quiet here today normally there are a lot more users online and posting - is InitialD ill?
Old 06-28-2004, 06:31 AM   #13213
lagnaf's Avatar
Default Re: Re: Re: Re: Re: Re: Pipe repair and protection
Realy strange
Maybe they all have a hard weekend behid them and need a few days of rest.
I hope that Pyramid will post what is this putty around the tail pipe.
Where the hell is InitialD i hope his allright.
Will post the pictures of my car and the repaired pipe if it sucseed.
Thanks for help Mark
Old 06-28-2004, 06:42 AM   #13214
markp27's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Pipe repair and protection
Realy strange
Maybe he's looking for his Ring
Good luck with the pipe.
Cheers, Mark.
Old 06-28-2004, 07:20 AM   #13215
teammpp's Avatar
OK
Will do so!
Cheers, Ognjen
Its a metal epoxy resin. The same type as standard 5-min epoxy (mix 2 parts together) but is metal filled.
