Serpent 710
Old 02-09-2004 | 10:43 PM
  #4186
markp27's Avatar
MR D,
Do you know which K&N filter fits to the SS 3 port? At rccarinternational there are several sizes and I'm not sure which one fits.
Cheers, Mark.
markp27 is offline
Old 02-09-2004 | 10:59 PM
  #4187
InitialD's Avatar
I remember Jan wanted to sell me the K&N filter. It looks nice but I think a normal sponge type will work fine. In fact cheaper too.
You basically have to buy the aluminum adapter if I'm not mistaken. Then the K&N filter goes in. I can't remember what adapter goes in a .12 engine. You can ask them via email.
InitialD is offline
Old 02-09-2004 | 11:06 PM
  #4188
markp27's Avatar
Ok, I thought you'd said one time about the K&N being good - I've dreamt it I think Ok, will stick with the sponge.
Just getting my list of spares ready Putting an order in for all upper and lower suspension arms
markp27 is offline
Old 02-09-2004 | 11:10 PM
  #4189
InitialD's Avatar
Why not get another complete kit just for spares? If you calculate it out, I think you'll only get a few separate things for the same price of a complete kit...
InitialD is offline
Old 02-09-2004 | 11:19 PM
  #4190
markp27's Avatar
I know what you mean, but I normally break the same parts, so I'd end up having a load of parts which I may replace once in two years, but a few parts which I would replace a few times.
markp27 is offline
Old 02-10-2004 | 01:51 AM
  #4191
Sow&Steady's Avatar
My philosophy exactly ...
Plus, those parts you don't need immediately such as 2-speed clutch set etc will eventually come in handy when the older one wears out.
Yet others such as the pinion set, what I do is have them installed with other sizes (16-21) and I keep the original 17-22 pinions as spares or ... see below.
Above all else, if you happen to drive at a track where there are others with the 710, you'd most likely end up being the good samaritan who just happen to have that part he needs.
Sow&Steady is offline
Old 02-10-2004 | 02:20 AM
  #4192
InitialD's Avatar
Aha, but you're taking the 2nd kit and building the lightest car this side of town has seen ! Remember?
You're using 21T pinion? I find that using about 60 to 62 mm tires with the stock 22T pinion is about right for the normal straights at Titi. Unless you have an engine which can scream 48,000 rpm !
Really? Oh good samaritan, where are you when I need you for spares?
InitialD is offline
Old 02-10-2004 | 02:36 AM
  #4193
markp27's Avatar
Anyone tried the serpent bearing oil?
markp27 is offline
Old 02-10-2004 | 02:50 AM
  #4194
InitialD's Avatar
Not yet available here from what I can tell... Apparently it's good stuff. Planning to get it?
InitialD is offline
Old 02-10-2004 | 02:52 AM
  #4195
S710_Nut's Avatar
Default Re: Re: Re: Re: Droop!
I don't get you... Increasing droop means for example +7 to +5 on the droop scale.
Oh, yes, I also remember than rubber tires work better when front and rear sway bars are taken out. Set the car for as little camber change as possible and use lower roll centers to get more grip. The idea is to make the car roll more.
S710_Nut is offline
Old 02-10-2004 | 02:54 AM
  #4196
S710_Nut's Avatar
Yes Very nice... I just followed the report on mytsn on cleaning them and applying the oil etc. I used the Eagle Racing bearing cleaner with Shellite.
SN
S710_Nut is offline
Old 02-10-2004 | 02:55 AM
  #4197
S710_Nut's Avatar
Try rc-mushroom
S710_Nut is offline
Old 02-10-2004 | 03:00 AM
  #4198
InitialD's Avatar
Originally posted by S710_Nut
Try rc-mushroom
Just for a bottle of bearing oil? That would be overkill. The problem is when I start adding stuff to make upo for the shipping, I'll blow out my pocket !
InitialD is offline
Old 02-10-2004 | 03:01 AM
  #4199
InitialD's Avatar
Default Re: Re: Re: Re: Re: Droop!
Anyway, why do you need to run rubber tires? We run on a slightly rough cement track with foam tires. 40 shore or even 37 if you feel like spending more on tires !
InitialD is offline
Old 02-10-2004 | 03:09 AM
  #4200
S710_Nut's Avatar
Default Re: Re: Re: Re: Re: Re: Droop!
I have never seen anyone succesfully run on our track with foams... rubber tyres aren't that bad, $8usd for the tyre and insert can be reused, i do have a bad habbit of buckling the rims though. I might try a frnt roll centre change to see what that does to my mid corner steering. What impact will that have on entry and exit steering though?
SN
S710_Nut is offline
