Old 02-13-2004, 11:14 AM   #4336
markp27's Avatar
Send a message via ICQ to markp27
Originally posted by serpentracer1
Anyone know what happened to Rene C. He had a 21-5.07 in the first round than later on they have him only running once with an 8 lap something
I think Rene may have been there in the main to provide support to Michael and not to be racing himself. He is though a very good racer, being a regional German champion last year.
He'll let us know when he comes back
markp27 is offline   Reply With Quote
Old 02-13-2004, 12:54 PM   #4337
cyba888's Avatar
Does the factory charger that comes with the Futaba remotes charge ni-mh batteries? You know the one with 2 red lights on the adapter,1 for the rx and the other for tx? Actually I found one laying around but its a Hitec one. Not sure if it will work with a Futaba remote. The polarity should all be the same correct? Im guessing it should be universal.
Here are the specs for the Hitec Ni-Cd charger.
Input 117VAC 50/60Hz 4VA
Ouput TX 10.8V DC 55ma
Rx 4.8V DC 55ma
Should I see if it works or is it too much of a risk?
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 02-13-2004, 12:56 PM   #4338
cyba888's Avatar
The Mazda 6 will be in stock next week so im definatley going to pick one up. Im kind of tired of the looks on the Stratus bodies
Futaba 4PX
Old 02-13-2004, 01:09 PM   #4339
cyba888's Avatar
Is there any normal wear and tear I need to watch out for on the 710? I heard someone mentioned that some kind of shims need to be replaced as they get worned out?(forgot which ones) Im talking about anything doing with the clutch, gears, thrust bearings or anything similar?
Futaba 4PX
Old 02-13-2004, 01:32 PM   #4340
Trader Rating: 25 (100%+)
Down here in Puerto Rico there are a couple of racers that have actually raced the car, with good results. The car seems to be a little soft in the rear but I think this car wasn't made to be smashed against the walls!! Still, the car to beat (so far) is still the MTX-3 al least down here!
madness is offline   Reply With Quote
Old 02-13-2004, 07:08 PM   #4341
Pyramid's Avatar
When the pinion gear (standard) and spur are worn out, it`s better of changing both at the same time to avoid stripping. Shims on the first gear also.
Yes, the Mazda body is great. We`ve been selling about 50+pcs in the last 2 weeks
Madness... I think that`s driver factor. S710 has blast MTX3 on its firts meeting by overlaping in 5 minutes run in here.
Pyramid is offline   Reply With Quote
Old 02-13-2004, 08:28 PM   #4342
But dont be so ..
Im right behind you, my finger + 710 is getting better and better and "I'm Faster Now !!"
GoldFinger is offline   Reply With Quote
Old 02-13-2004, 08:33 PM   #4343
Pyramid's Avatar
Originally posted by GoldFinger
But dont be so ..
Never use last year statment in this year...
Old 02-13-2004, 11:19 PM   #4344
Default Watchout !!
Just pay more attention for this car ....
Old 02-13-2004, 11:23 PM   #4345
Originally posted by PUNISHER
Are you useing the Lola bumper for the top bumper plate for the 710??
Can you post a picture of that so I can see what you are talking about....thanks.
Sorry for being so long..
Here s what I mean bulletproof bumper
Front View :
Old 02-13-2004, 11:25 PM   #4346
Top View :
Old 02-14-2004, 02:11 AM   #4347
Sow&Steady's Avatar
Default Re: Watchout !!
Goldfinger, in your opinion what is the advantage of using the 705 bumper if you're using the Loletta shell?
I find that with the Loletta shell, you can use the original foam bumber and only need to trim a small portion up front into a slope.
With this, I think the car is able to withstand bigger bumps plus you can swap between VDS and Sedan shells at will.
Sow&Steady is offline   Reply With Quote
Old 02-14-2004, 05:20 AM   #4348
Default Re: Re: Watchout !!
Coz there is no other alternative.. 710 Lola bumper will be perfect and the front body mounting is separated with bumper but hasnt release yet..
That is sound good too..
For me, my goal is the shell must stay in place (correct position)
after a hard crash, even with broken bumper plate or 1 post left.
With stock 710 bumper and plate.. i gave up already after replace it 4 times.
Old 02-14-2004, 09:05 AM   #4349
InitialD's Avatar
Originally posted by markp27
Hope so too! Look forward to hearing your impressions. It looks as though it has met with a lot of racers approval.
Mark, I don't think I'll get to drive the shell. I've cut it already but I've still not painted it yet !
Old 02-14-2004, 09:11 AM   #4350
markp27's Avatar
Weekend just keeps going downhill - starts well with pretty girl next comes the hangover weather doesn't allow me to get to the track and now no test report
But you should be able to photograph its nakedness!!! Go on, brighten my weekend up
