Old 05-28-2004, 06:41 PM   #11566
SupermaxxRich's Avatar
Thanks "D", once again!
SupermaxxRich is offline   Reply With Quote
Old 05-28-2004, 07:26 PM   #11567
teammpp's Avatar
Originally posted by JustRace
D,
I thought the tire size wouldn't affect your droop. I would think you need to change the droop if you use the shock collar to adjust your ride height.
Both tire size and ride height affect your droop. If you alter either you have to correct the droop to keep it proper.
teammpp is offline   Reply With Quote
Old 05-28-2004, 07:27 PM   #11568
teammpp's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Clutch
Originally posted by Sow&Steady
KevinS, thanks very much for that excellent explanation.
The confusing part for me was that I was referring to the rear layshaft and the front or mid shaft to be either made of Ti or hollow spring steel. I thought then that these would be sprung weight since they "sit" on the chassis it self right?
That is correct.
Old 05-28-2004, 08:21 PM   #11569
Pyramid's Avatar
D,
There are many jargons being use for that kind of thing such as downstops, droops, rebound stroke, etc.. each of course has `meant` to be different in meaning. Anyway I`m kind of understand what you meant and yes it does not effect the reading
Pyramid is offline   Reply With Quote
Old 05-28-2004, 10:32 PM   #11570
Unhappy
just bought a battery pack for my serpent and am having alittle trouble becuase the connecting end on the pre made rechargeble pack cant connect to anything because the connecting end on the on/off switch only has two wires and the rechargeble battery pack has three and i cant connect it to the on/off swith because it the two end pecies dont match each other what do i do?
baller360 is offline   Reply With Quote
Old 05-28-2004, 11:46 PM   #11571
PSI Racing's Avatar
Cut it off and add the right plug that you need.
PSI Racing is offline   Reply With Quote
Old 05-29-2004, 12:32 AM   #11572
even when i connect the battery pack directly to the reciever it doesnt work. does the battery pack need to be recharged first i just got it its new and i havent used it as yet. and its made by serpent its the 700mah pack do you have to recharge these packs the first time you get them? because mines seem as though it needs to recharge or it just doesnt work with my reciever.
Old 05-29-2004, 01:08 AM   #11573
PSI Racing's Avatar
Try charging it up first.
Old 05-29-2004, 02:41 AM   #11574
InitialD's Avatar
Default Re: Re: Sandblasted piston
Originally posted by pelos
Anyway P/S + conrod + rear bearing is 160 USD at mushroom, I will think over, don't know if it is worth since for 260 USD I can have a new engine...
Ummm, that's a hard call. I remember reading some economics book or something along the lines that if the repair is like more than 75% of the cost of the engine, then might as well get the new engine. But then again, the piston sleeve, conrod and the main bearing is like about 60% of the cost of the new engine... It's your call.
If you can sell parts of the engine like the carb, the front bearing or the crankshaft or even the engine crackcase, then I would do so. Else, if you look the other way around, you have spares that you can play around and do some test if you're interested in modding stuff...
Old 05-29-2004, 02:42 AM   #11575
InitialD's Avatar
Ahh, you're most correct. I thought I mentioned somewhere in that reply that you only reset the droop when you use smaller / bigger tires AND set the ride height back to original. Of course when you're using 64 mm tires and with 5 mm ride height and then decide to change to 60 mm tires, you'll end up at 3 mm ride height and you won't want to change it back to 5 mm ride height?
Old 05-29-2004, 02:45 AM   #11576
InitialD's Avatar
Ooophs... I thought when you mentioned titanium shafts, you were referring to titanium dogbones (because rear layshaft and the front or mid shaft in titanium is already readily available) to which I replied titanium doesn't have very good wear properties especially when used as a dogbones.
Anyway, aren't we all using titanium main 2 speed shaft and the mid shaft already?
Old 05-29-2004, 03:16 AM   #11577
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Clutch
Oh I C. I would have thought Hudy spring steel dogbones would be nice and the preferred choice. If they ARE avaiable I've not seen them sold yet.
I didn't know that Serpent already made Ti main shafts! I've got the Serpent Ti front/mid shaft already. but had to buy the Shooter main shaft.
Somehow I do not have a good feeling for Ti dogbones though. In fact the wear properties and brittleness would show up more so in dogbones than in Ti shafts. If dogbones were made of Ti, I'm almost sure that the first thing to go would be the bits at the end that goes into those drive slots.
Not me This rebuild will definitely include them now though
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 05-29-2004, 08:09 AM   #11578
pelos's Avatar
Default Re: Sandblasted piston
Interesting way, master D, but no idea about any mod... help!
pelos is offline   Reply With Quote
Old 05-29-2004, 08:42 AM   #11579
InitialD's Avatar
I think you should be able to let us some in on mods ! Besides you live in the land of micro motori.
Old 05-29-2004, 08:53 AM   #11580
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Clutch
Our bros Pyramid / Goldfinger (and probably some others) have noted and reported that the Impact front dogbones are not made by Hudy already...
Serpent Ti? You meant 3 Racing...
Didn't you sapu every single titanium 3 Racing stuff when you were back?
