Serpent 710
Old 05-09-2004 | 11:05 AM
  #9916
markp27's Avatar
Default Re: Re: Re: Re: Re: Re: Thrustbearing after run.
Originally posted by crashed_1
Me wanna go too...
GET A TICKET MAN! Hey, then D can carry your bags and get on for free
markp27 is offline
Old 05-09-2004 | 11:06 AM
  #9917
InitialD's Avatar
Originally posted by markp27
How do you mean it jumps up on the starterbox?
On throttle, the rear hubs and wheels would jump slightly...
InitialD is offline
Old 05-09-2004 | 11:07 AM
  #9918
markp27's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Thrustbearing after run.
Originally posted by InitialD
Really?
Ummm, then again, you would run circles around Julius, Rene and Michael !
That could be embarassing for the guys I fully intend to let the trounce me and make me look a complete idiot.....only to make them feel good and not that I'm useless
markp27 is offline
  #9919
InitialD's Avatar
Ummm, are you sure you did not confuse the existing Master / Slave relationship?
InitialD is offline
Old 05-09-2004 | 11:08 AM
  #9920
markp27's Avatar
There will be a high twisting force generated by the wheels spinning....nothing loose in the suspension area or pivot balls?
markp27 is offline
Old 05-09-2004 | 11:09 AM
  #9921
InitialD's Avatar
Default Re: Re: Re: Re: Re: Thrustbearing after run.
So, D, as Michael was so kind in visiting you guys in Asia, are you going to repay the favour and come to the 200mm International at MACH? Burn those guys with your Mazda!
Like I mention, I need to win a lottery ticket to be able to burn those guys with my Mazda 6 (as if I could).
InitialD is offline
  #9922
markp27's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Thrustbearing after run.
Hey, what ever relationship is between you and Crashed, please keep it to yourselves
markp27 is offline
Old 05-09-2004 | 11:10 AM
  #9923
InitialD's Avatar
Hey, that's a very good excuse for any mistakes in driving you make.
InitialD is offline
Old 05-09-2004 | 11:11 AM
  #9924
markp27's Avatar
Anyway, it would be a good cover to not alert the fans in Amsterdam airport of your arrival - could turn nasty, otherwise
markp27 is offline
Old 05-09-2004 | 11:12 AM
  #9925
markp27's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Thrustbearing after run.
If only I had thought of that
markp27 is offline
  #9926
InitialD's Avatar
I thought so too until crashed_1 pointed that out to me. True enough I went home to grind those dimples away and the "jump" went away.
I think it is because the dogbones are free to move in the lateral position. And because the dogbone can sit in the dimple or sit elsewhere in the outdrive, there is a difference in play and makes for the "jump".
InitialD is offline
Old 05-09-2004 | 11:14 AM
  #9927
InitialD's Avatar
Only drove about 4 tanks, but due to the conditions a tank was lasting quite a while - a few guys from the club came by when they saw someone was driving in those conditions - seemed all to leave with the impression that I'm completely mad
Yup... I think you really need help, Mark. RC anonymous anyone?
InitialD is offline
Old 05-09-2004 | 11:16 AM
  #9928
InitialD's Avatar
Default Re: Thrustbearing after run.
Here is my thrust breaing after driving today - looks intact but most of the grease is migrated from the bearing It needs a clean and re-grease for saftey's sake.
Yup. Leave the grease in the balls. It will be fine.
InitialD is offline
  #9929
markp27's Avatar
I working on the principle that Ayrton Senna honed his driving talent by practicing in England whenever it rained - hey, if it worked for him.....
markp27 is offline
Old 05-09-2004 | 11:17 AM
  #9930
InitialD's Avatar
Default Re: Re: Thrustbearing after run.
Mark, if you're using Mugen Super Grease on your thrust bearings, they'll probably last you a good 3 weekends of bashing before a regrease is needed. These grease are great for the diff balls too.
InitialD is offline
