Old 05-09-2004, 10:41 AM   #9901
Sow&Steady's Avatar
Originally posted by Picard
Hey Gav
I need to know if the sato's or GQ'd will be OK, I think there are a few guys in this thread that would know...
I hope...
Picard, I've used GQs, they were 2mm offsets in the rear if I'm not mistaken. Fronts were zero.
I've stopped because I was out in the tropics and found them take a while to heat up and then overheat soon after!
Haven't tried Sato's with the 710, only the MTX3 ... not bad.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 05-09-2004, 10:42 AM   #9902
Motorman's Avatar
I run GQ and the 0 offset fits fine front and rear. we won't run anything else anymore.
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 05-09-2004, 10:46 AM   #9903
markp27's Avatar
Send a message via ICQ to markp27
Default Re: Re: Re: Re: Thrustbearing after run.
Originally posted by crashed_1
Makes me dizzy too...
A thrust bearing from a NTC3? Better not let D see this man...he'll go hysterical.
DELETE!!! DELETE!! Oh god, I'm doomed
Has D used his shell?...He was smokin our local track with it...
D's the king!
He was having some problems with rear traction lately. Had a bouncy rear end and found the outdrives on the rear badly eaten up by the doggy bones. The rear suspension/wheels tend to move up on acceleration.(More apparent on a starter box) It happened to mine too but managed to cure it with a set of new outdrives.
Really I notice in comparison to the 705 there wheels turn much further before the dog bones engage into the outdrives - I suppose lots of power and this larger gap leads to them getting eaten up!
markp27 is offline   Reply With Quote
Old 05-09-2004, 10:49 AM   #9904
markp27's Avatar
Default Re: Re: Re: Re: Re: Re: 200mm International at Heemstede
Originally posted by Sow&Steady
Yeap .. Wifey-Work thing(s). Anyway, glad to hear that you managed to drift! Now, if I only could find those RC Drifting videos I downloaded ages ago ... could then post them on 3Hobby!
I too decided to go and have a look at the track. Luckily I didn't bring the car(s), the BRCA 1:10 Electric Nationals was on! Track slightly damp but those guys were flying regardless! Now I need to go figure how to download the short video I captured onto the PC.
Yeah, the drifiting was great fun and also when the back end would suddenly step out - a bit of opposite lock and keep your "foot" down
I'd be interested in seeing those vids if you can dig them out
What tyres where the electric guys using? Maybe you should get some rubber tyres, too and go and blast the track
Old 05-09-2004, 11:49 AM   #9905
InitialD's Avatar
Default Re: Re: Re: Thrustbearing after run.
Originally posted by markp27
Hey, crashed_1 old budy! How you doing - god!!! What is that for an Avatar!!!!!!!!!!!!!!!!! I feel ill
That's what happens when you're too creative and have too much time in your hands !
I'm just a bit paranoid until I get some spare thrust bearings - after I blew mine yesterday, a friend kindly offered me one of his from his TC3 Nitro - the hole measured 4.4mm in the carrier so close yet so far
You can go to any bearing shop and get those thrust bearings. Size is 5x10x4. BTW, if you must know, the Mugen MTX-3 also uses the same thrust bearings in their clutch.
Has D used his Mazda shell yet?
Old 05-09-2004, 11:54 AM   #9906
InitialD's Avatar
That's passe for you... Remember?
Has D used his shell?...He was smokin our local track with it... He was having some problems with rear traction lately. Had a bouncy rear end and found the outdrives on the rear badly eaten up by the doggy bones. The rear suspension/wheels tend to move up on acceleration.(More apparent on a starter box) It happened to mine too but managed to cure it with a set of new outdrives.
Smokin? Look who's smokin the track ! Whoosh !
The body was nice. But I thought the PF Stratus 2.1 had more steering. Maybe it's just me or that I mounted the Mazda 6 a little too much to the rear causing too much rear downforce. I will try to cut down on the rear wing smaller to see the effect.
Yup. I grinded the dimples in the outdrives of the rear ball diff and it was very smooth. The rear does not jump up on acceleration on the starter box as well as on the track. But after a few tanks, I thought I saw the rear do that again... I need to check.
Old 05-09-2004, 11:56 AM   #9907
InitialD's Avatar
Default Re: Re: Re: Re: Re: Saturday surpise!
Originally posted by Taylor-Racing
Hi "D",
You mean the 5.2 mm goes closest to the clutch bell, don't you?
Oh, thanks for the correction ! My bad.
Old 05-09-2004, 11:56 AM   #9908
markp27's Avatar
Could be worse
Aha! Finding one is the problem though
So, D, as Michael was so kind in visiting you guys in Asia, are you going to repay the favour and come to the 200mm International at MACH? Burn those guys with your Mazda!
Old 05-09-2004, 11:58 AM   #9909
InitialD's Avatar
Default Re: Re: 200mm International at Heemstede
Yea! This sounds good! MarK? Where are you hiding? Let's go man!
Yeah, like I said... If I strike the lottery ticket !
jfc_tech, is there a sure win ticket for me?
Old 05-09-2004, 11:59 AM   #9910
crashed_1's Avatar
Default Re: Re: Re: Re: Re: Thrustbearing after run.
One used outdrive coming your way to be rejuvenated...
crashed_1 is offline   Reply With Quote
Old 05-09-2004, 12:00 PM   #9911
crashed_1's Avatar
Me wanna go too...
Old 05-09-2004, 12:01 PM   #9912
InitialD's Avatar
They were +2 offset in the rear because a certain LHS brought them only for a certain car ! Jeez... They probably thought every one runs +2 offset. I got 0 offset rear GQ tires before and liked it very much. That was actually the onset when GQ tires were known here. Could not find those 0 offset ones anymore...
If you liked Speedminds, then you would like Sato too.
Old 05-09-2004, 12:03 PM   #9913
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: Thrustbearing after run.
Me wanna go too...
Really?
Ummm, then again, you would run circles around Julius, Rene and Michael !
Old 05-09-2004, 12:04 PM   #9914
markp27's Avatar
D, how many times do I have to tell you that this bourgeois language is passe
I was getting this impression with the Surikarn, too! But I have a huge wing at the rear - maybe I'll cut it down a bit
How do you mean it jumps up on the starterbox?
Old 05-09-2004, 12:04 PM   #9915
InitialD's Avatar
One PF Alfa 2.1 bodyshell to be nicely painted coming your way...
