Serpent 710
Old 05-07-2004 | 05:03 AM
  #9736
markp27's Avatar
Originally posted by KevinS
And the same goes for me.
I think the bumper is too flexible to hold the body.
I'm sure I've got the small body posts, too - do you use the under body supports on the body posts?
markp27 is offline
Old 05-07-2004 | 05:04 AM
  #9737
cox049's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Camber (rear)
Originally posted by BaxterC
Thank you, The more I think about it, the more it will be an ALL Important tool, I am having nightmares about uneven shocks, I dread building shocks, but I think this would help greatly.
Baxter, this article has some helpful hints for the 710 shocks building
http://ashfordhobby.com/tech02.htm
cox049 is offline
Old 05-07-2004 | 05:14 AM
  #9738
BaxterC's Avatar
Have a look what I found for the starterbox:
Charger:
rccarinternational
And Packs... only the best for me.
cheapbatterypacks
But look at the GP3300 Double Stick Pack... I will need 2.
Do you think these are good prices? Remember that I will want it to be compatible with our power here (220v-240v) I dont want to charge from my car battery.
BaxterC is offline
Old 05-07-2004 | 05:18 AM
  #9739
BaxterC's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Camber (rear)
Thank you greatly... This really does help. Tell me, Is that your son in your avatar? I used to marshal offroad bikes and stadium trucks (real ones) many years ago. Does he race?
BaxterC is offline
Old 05-07-2004 | 05:27 AM
  #9740
markp27's Avatar
Default Engine + Pipe
The 2106 is not available at the moment and Serpent don't know when it will be available again.
Does anyone know if the TP06 is a good combination for the JP FX12 T03?
Cheers, Mark.
markp27 is offline
Old 05-07-2004 | 05:37 AM
  #9741
KevinS's Avatar
Nope, they dont fit... There are only 2 holes in those short body posts and there isn't enough room between the two to fit the supports, since the bodyposts end up right at that dimple in the GTP body. I only use the steel pins and stuck some thick foam tape (one sided) on the inside of the body.
Anyone else having trouble with mytsn? I keep getting "Page can not be displayed" errors. Or does anyone have the partnumber for the rear floating body mount that fits the 705?
Again, sorry for the 705 revival in the 710 thread.
KevinS is offline
Old 05-07-2004 | 05:48 AM
  #9742
cox049's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Camber (rear)
Yes Baxt my 6 year older he's not RTRace yet but I'm coaching him on the basics and he's building confidence and skill and really enjoying it
About the shocks, I followed Ashfords tips and ended with silky smooth shocks
cox049 is offline
Old 05-07-2004 | 05:53 AM
  #9743
PSI Racing's Avatar
I used the exact same setup.
PSI Racing is offline
Old 05-07-2004 | 05:55 AM
  #9744
PSI Racing's Avatar
Mytsn is working for me.
Here's the number for the floating body mount kit 808150.
  #9745
KevinS's Avatar
Those GP3300 packs will earn you the envy of electric racers. Some shops sell those packs for $70 and up!
The charger is great for charging those 3300mAh packs, but you can't slow charge your receiver packs with it... It starts at 500mA.
KevinS is offline
Old 05-07-2004 | 05:58 AM
  #9746
BaxterC's Avatar
Lovely, I am glad he is enjoying it, I would have loved to do it. Thank you for the tips, I have printed the tips and will follow them.
MyTSN is working fine, no problems here.
BaxterC is offline
Old 05-07-2004 | 06:04 AM
  #9747
BaxterC's Avatar
Lovely, thank you. What would you suggest for the receiver pack, I have a wall charger for them, bet you only get about 80% charge from them. I am sure that the starter will run for months on those packs.
BaxterC is offline
Old 05-07-2004 | 06:24 AM
  #9748
cox049's Avatar
Default GP3300
I bought a gp3300 for my glow plug ignitor and I find that it loses it's charge very quick when not in use. I charge all my batteries the day before race/practice and I always end up changing back to the 1300mah sanyo at the middle of the day
Maybe these batteries are great stuff for electric racing but you have to have them hanging from the charger all the time
cox049 is offline
Old 05-07-2004 | 06:34 AM
  #9749
Default Re: Clutch
Originally posted by PSI Racing
Is anyone using the stock Centax III, or has everyone modified theirs?
Would the new yellow clutch shoe (802509) help with the slipping clutch problem?
Here's a description of the new shoes.
To increase performance of the Centax 3 clutch system even further, Serpent are pleased to present the new yellow clutch shoe. The new material reduces the clutch slipping, which therefore allows more power to get to the wheels. This creates a more efficient performing clutch system but does make the engine work harder.
Isn't the stock clutch shoe an XP type?
I know on the older clutches the yellow was the stock clutch shoe.
They also had a black one that allows slip and an XP one that was supposed to give more punch.
If the stock Centax III shoe is an XP, why would the yellow one have less slippage?
Check out my myTSN article about building the Centax-3 clutch.
http://www.mytsn.com/publ/publ.asp?pid=10063
Hopefully some of your questions will be answered.
Regards,
GlennCauley is offline
Old 05-07-2004 | 06:38 AM
  #9750
cox049's Avatar
Default Re: Re: Clutch
Regards,
Glenn, Great article! Thanks and keep it up
cox049 is offline
