Old 10-09-2004, 03:01 AM   #17236
redsand's Avatar
Send a message via Yahoo to redsand
Default Middle Shaft Steel
What might caused a groove underneath the bearings on the middle shaft steel (#802161) ? As far as maintenance goes, the bearings are in good condition.
It came to a point where one of the bearings got stucked on it, the only way to get the bearing off was to smoothen the groove using a dremel tool, the middle shaft was then salvaged.
redsand is offline   Reply With Quote
Old 10-09-2004, 03:05 AM   #17237
InitialD's Avatar
Default Re: Middle Shaft Steel
Heat and friction !
Before assembly, rub some oil on the shaft where the bearings will be rolling. That would reduce the chances of the bearing scouring the shaft.
Old 10-09-2004, 03:13 AM   #17238
redsand's Avatar
Default Re: Re: Middle Shaft Steel
Originally posted by InitialD
Heat and friction !
Thanks for the input as usual, D.
Old 10-09-2004, 03:33 AM   #17239
Picard's Avatar
Default Re: Re: Re: Servo Saver Spring
Yup it looks a lot like the Centax spring but then again, our stock kit Centax spring diameter is 1.7 mm while the Centax II optional spring is 1.8 mm. Not 1.4 or 1.3 mm respectively that I've measured. Centax spring in the kit is gold in colour and this is silver !
Hopefully somebody can explain.
D
I just just been ordering some goodies and I noticed there is a servo spring black for the 950, perhaps this is a similar spring put in the wrong kit?
Picard is offline   Reply With Quote
Old 10-09-2004, 03:35 AM   #17240
Picard's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Vidz
Originally posted by Sow&Steady
Oh dear. I can't even make it across the English Channel by boat comfortably so forget sailing all the way Down Under. I'll be 90 by the time I get there!
Fix the starship Picard!
Cant find the chief, whenever you need him he is nowhere to be found
Old 10-09-2004, 04:05 AM   #17241
markp27's Avatar
Send a message via ICQ to markp27
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Vidz
You need to find Data quick
markp27 is offline   Reply With Quote
Old 10-09-2004, 04:06 AM   #17242
markp27's Avatar
Default Normal service is resumed
Fixed all the bugs in my photoshop dirt filter!
Old 10-09-2004, 04:52 AM   #17243
Sow&Steady's Avatar
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 10-09-2004, 04:54 AM   #17244
Sow&Steady's Avatar
Default Re: Re: Re: Re: ehm?
Didn't realise ! Now wonder I had a hard time sleeping yesterday.
Oh, all those prayers from us lowly tech nuts praying for MS that he wins the WC got to you! Amazing o' Prophet!
Change to Sow&Steady2?
Hey! Thats a grand idea!
Old 10-09-2004, 04:56 AM   #17245
Sow&Steady's Avatar
Originally posted by markp27
Glad to see you know where the truth lies!
I am a man of truth plus we have a prophet lurking around.
Plus, I don't want to discourage you from racing with me again.
Old 10-09-2004, 04:59 AM   #17246
Sow&Steady's Avatar
Default Re: Normal service is resumed
[B]Fixed all the bugs in my photoshop dirt filter!
Blimey! That was quick work!
You sure you didn't use another just to show an asembled car?
Old 10-09-2004, 05:05 AM   #17247
markp27's Avatar
Default Re: Re: Normal service is resumed
Still working on the setup, though - after one o'clock here Clouds still looking heavy and I've got a lot of tweaking work to do - and charge my batteries.
Old 10-09-2004, 05:08 AM   #17248
Sow&Steady's Avatar
Default Re: Re: Re: Normal service is resumed
Well, sacrifice the rabbits. You might just buy enough time to do the set-up!
Old 10-09-2004, 05:59 AM   #17249
markp27's Avatar
Default Re: Re: Re: Re: Normal service is resumed
Phew! finished - well, I'll have a look down to the track to see if it is at all driveable - i.e. not too many leaves on the circuit!
Old 10-09-2004, 07:57 AM   #17250
InitialD's Avatar
Hey Mark, it looks like there are some bugs with that photoshop filter !
1. No fuel tubing? How does one expect to start the engine?
2. Pipe looks like it did not get the full effect from the filter.
3. Shock tower ! It's not broken !
4. Rubber tires? You've got to be kidding me.
