Old 12-29-2003, 07:05 AM   #2236
Sow&Steady's Avatar
Originally posted by Ducati998
Right on man, could not agree anymore with you. Maybe this guy was thinking of the 705.
Yeap, not only that, the G4s are they used are probably souped up and costs 3 times more than the 710s (or 705s for that matter!)
Sow&Steady is offline   Reply With Quote
Old 12-29-2003, 07:09 AM   #2237
Sow&Steady's Avatar
Originally posted by Pacman25
Josh Cyrul (Great Driver) came to OZ with his G4 and didn't make the final of Nitro touring. What does that mean, same as your comment absolutely nothing.
Have a nice day!!!!
Right on mate! And Brisbane has some great tracks too ...
Zizu, sorry for poking at you but your original statement was a little shallow and certainly done in the wrong forum.
Seriously, compare apples to apples next time ...
Old 12-29-2003, 07:56 AM   #2238
Default Re: Bearings!
Originally posted by S710_Nut
Would you guys bother removing the shield from the bearings cleaning them and replacing the oil with a teflon based lub before use?
Also,
How often would you clean the bearings? After every meet?
SN
http://www.mytsn.com/publ/publ.asp?pid=9214
RobbyDV is offline   Reply With Quote
Old 12-29-2003, 08:00 AM   #2239
InitialD's Avatar
Originally posted by Sow&Steady
Oh? Then you guys with the G4s need to go over to Malaysia and race with D!
And Serpent will definitely get a bad name and bad sales !
Old 12-29-2003, 08:01 AM   #2240
InitialD's Avatar
Default Re: Re: Bearings!
Rob, I'll try the 1682 oil. But then it's not available yet. At least here...
Old 12-29-2003, 08:21 AM   #2241
EVOLUTION's Avatar
Originally posted by Zizu
The new 710s got blown away by G4s at our local race. :
Is this Zizu Zidane?
EVOLUTION is offline   Reply With Quote
Old 12-29-2003, 08:45 AM   #2242
Originally posted by InitialD
It depends if you need to be legal or not.
I know the guys going to Winternats (ammdrew and fmolzer) are going to be running 3 port NovaMax engines. I'm not sure of the pipe though but I thought fmolzer mentioned it as being the new Novamega TP06.
As for me, I'm currently running mine with a 5 port Novamega MS engine and an outlaw 7 mm Shark inline pipe. Look at the pics of the car I posted. I notice that I needed to run it richer on the HSN. The engine revs crazy and the low end torque is good with the long manifold.
Thanks D. Our racing scene here doesn't limit us on engines so legal or non-legal ones are fine. Is your 5 port the 7105TMS one ?
nad138 is offline   Reply With Quote
Old 12-29-2003, 08:55 AM   #2243
Pyramid's Avatar
Default Re: Mugen MTX-3 or Serpent 710?
Originally posted by DrifterX86
Just got some Christmas cash and I want to spend it on buying a new R/C car. I'm currently debating on which kit to get? An MTX-3 or a 710? I just want to get an idea of what people think of both kits and why they chose a certain car over the other. Thanks...
Rumors has said Mugen will release the newer Mtx next year.. probably on spring.
All cars basically is the same, good one will be a good balance car which you could easly judge by laying them all together and see which one will be more balance for you and why? Durability will come next for judgement (for me at least). Do remember, balance is in close relathionship or equal to weight. A car with engine mounted will have different weight as also a car with `fuel` loaded or unloaded. Sure, aside from which one you think is a better balance one, the most important is will you be able to easly get parts for it?
Pyramid is offline   Reply With Quote
Old 12-29-2003, 09:02 AM   #2244
InitialD's Avatar
Nope. It's the 2104TMS.
Old 12-29-2003, 09:07 AM   #2245
Pyramid's Avatar
Pyramid, I have not noticed this on mine. I need to take it off to check and notice this.
Conform they are different in height (by comparing with gold fingers car also) with correct placement for front spacers. It is the back one, mid bracket, that sits lower. Try to measure by caliper from chassis to upper deck, middle bracket side, and front steering servo side. Actually, if you raise the mid bracket one by 0.95-1mm, you could actually milling down the chassis right below throtle servo by 1mm (I guess) to have the servo mount under the top deck for higher self confindence in gravity
Another thing, Serpent shocks are way to advance for me... I wish they could have design the conventional one from the ground for such a user like me.
Old 12-29-2003, 09:10 AM   #2246
Pyramid's Avatar
Its a great car, I drives one also. But if I were you, I will post that statement on G4 threads.. just my opinion only
Old 12-29-2003, 09:24 AM   #2247
InitialD's Avatar
What is so advance about it? Hard to build? You should have built the ones that come with the Impulse Streetspec / Impulse PRO ! If you pass on the first try, it will make you an instant shock expert builder !
But seriously, they are one of the best around. Imagine that you can adjust externally the setting of the shocks without even taking the shocks apart to change piston holes... Just like the external rear / front ball diffs.
Old 12-29-2003, 10:25 AM   #2248
I noticed this from the very start, right after putting the top deck. Truly it does not really matter but I think the question is why they design like this ?
GoldFinger is offline   Reply With Quote
Old 12-29-2003, 10:44 AM   #2249
Sow&Steady's Avatar
Do you happen to know if he used the stock settings?
D, is that a trick question?
Old 12-29-2003, 10:48 AM   #2250
Send a message via ICQ to lawndoggie Send a message via Yahoo to lawndoggie
Master D can kick Salven's ass with an OS engine!!
and some CA glue on Salven's steering servo.....
lawndoggie is offline   Reply With Quote
