Old 04-29-2004, 06:30 AM   #9166
InitialD's Avatar
Default Re: cvd,s
Originally posted by Rebal
For the same reason. I,ve worked with narrowing track widths and personally use the brass washer from glow plus to space out the outdrive on my one way.
Yup. I forgot to mention that tip. I believe that came from Dark Lord Julius somewhere. But I think Schrijver99 mentioned that this will cut the oneway shafts. He mentioned something about the things sponsored factory drivers do versus what normal drivers do...
Anyway, good luck racing and let us know how it turns out !
Old 04-29-2004, 09:23 AM   #9167
cox049's Avatar
Default Re: Re: centaxIII clutch shoe duration?
Originally posted by InitialD
I don't know if it's something wrong with me but I never had to change the clutch shoes... All this while, it's the same clutch shoe I put in the car.
Why are you changing them? Because of wear? Did the clutch shoe melt? Perhaps your clutch is slipping very badly.
Did you mod the flyweights? What are your clutch settings? I assume your engine is tuned right.
I changed one and I see the new one going kinda quick. It's normal wear to the edge of the aluminum tray, no melting. I do have it set to engage pretty high in revs... maybe driving it that way causes more friction than would be desired...and my engine is tuned correctly "sometimes"...
Anyway, knowing that you don't have this problem is very useful for me so I can work on better adjustments . Thanks for the info "D"
cox049 is offline   Reply With Quote
Old 04-29-2004, 10:59 AM   #9168
Wap
Default Re: Re: Re: Wap
Originally posted by markp27
Now I know women as badly as the next man, but this sound like a case of "heads I win and tails you loose" i.e. if you don't go, you'd be blamed for your wife picking the wrong house, and if you do go, it'll be your fault for picking the wrong house
your absolutely right, i can't win.
I should be ready to race next weekened; i'm anxious to put the 710 on the track.
Wap is offline   Reply With Quote
Old 04-29-2004, 11:03 AM   #9169
Wap
Default Re: Re: Re: Re: Wap
you hit on the head. It's no way i kind win.
Old 04-29-2004, 11:06 AM   #9170
JustRace's Avatar
Default Re: 710 CVD,s ????
Does anyone make CVD,s for the 710.I,ve looked around and found none. This seems like a basic hop up item that everyone and their mother has. It a great car that I enjoy much.But it bugs me that a minor hit to the wall and the dog bone pops out. I,ve tried running Impact dog bones because they are just a bit longer and it helped maybe a little. Why would there not be dog bones? What do the Pros do besides not hit anything???
I got a set from SouthWest RC. I tried them last week at the Twister Tire Challenge and they held up. I used them for practice, 5 qualifiers, and a 30 minute main.
http://www.swrc.biz
JustRace is offline   Reply With Quote
Old 04-29-2004, 11:07 AM   #9171
markp27's Avatar
Send a message via ICQ to markp27
Boy, tell me about it! I've had my 710 since sometime in Jan and because of snow, non delivery of motor and servos, it still hasn't turned a wheel I wanted to go to the track last weekend, but there was a race on. I'm just hoping that everything comes together this weekend and I can head on down to the track.
markp27 is offline   Reply With Quote
Old 04-29-2004, 11:36 AM   #9172
Herbie's Avatar
I hope the weather stays nice Mark. The forecast is not that good and I'll have to race sunday but I hope it stays dry during the weekend.
Herbie is offline   Reply With Quote
Old 04-29-2004, 11:38 AM   #9173
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Radio
Originally posted by BaxterC
Y... My rccar order will ship tomorrow... Eventually.
Aha! Start greasing your palms man!
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 04-29-2004, 11:41 AM   #9174
Sow&Steady's Avatar
Best northern english ice Never feel a thing from the cold Getting too warm on a morning now, though. It was 13 degrees C this morning - almost sucummed to heat exhaustion!!!
Yeap, considering I'm made and manufactured in the tropics, I was surprised that I was also "fried" this morning in London when it was only 12 DegC!
Mind you, in a feeble effort to lose weight, I was trying to walk as fast as I can ... and OK, it wasn't very fast.
Old 04-29-2004, 11:48 AM   #9175
Car Breaker's Avatar
Default Re: Re: 710 CVD,s ????
3 Racing makes them. But as KevinS pointed out, they may not be the realy CVD. Just a dogbone with a pin. Don't know about their reliablity though and they can be suspect.
Dogbones are more rugged. If you hit and rub the walls with a CVD, it'll be a more costly replacement and you need to replace it when it gets bent. Dogbones will just pop out or get loss. To a certain extent, you can still use your slightly bent dogbone.
tried that yet.
I think 3racing CVD should be ok, i have them on my G4 and i crash it many times , only one has slight bent , but their QC is just so so wish you luck buying them ( i buy 3 pair and only 2 pair can be use )
Car Breaker is offline   Reply With Quote
Old 04-29-2004, 11:52 AM   #9176
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Radio
You should cycle over here. 30 to 35 degree C with high humidity !
Was there last week, missed you at TT by a whisker on Sunday. Was drenched by the time I walked from the track to the car!
Anyway, shops seemed to whine about the slow cash-flow. You need to buymore stuff from ol' Thomas!
Old 04-29-2004, 11:55 AM   #9177
Sow&Steady's Avatar
I should race tonight at the indoor track but too knackered to even lift my transmitter!
Gotta scoot over the pond this Saturday so can't race again either ... what to do?
Well, I'll work on my new RC website I think ...
RC Reviews is looking to dogged to get excitement.
Old 04-29-2004, 11:57 AM   #9178
Sow&Steady's Avatar
Default Re: Re: Re: 710 CVD,s ????
I was about to say the same thing about their QC but didn't want to be labelled "anti-3 Racing"!
Old 04-29-2004, 12:11 PM   #9179
Trader Rating: 2 (75%+)
This might be a dumb question..................
Are these CVD's are made for front and rear or just fronts??
PUNISHER is offline   Reply With Quote
Old 04-29-2004, 12:27 PM   #9180
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
the 710 should be the same front and rear
