Serpent 710
#1606
Originally posted by Thaasman
Got mine too from yesterday
Manual seems to be OK...
And the setup book is very interesting
Well....Back too work
I am keen to know how it goes together and how they start to perform out off the box..
SN
#1607
Originally posted by S710_Nut
Thanks,
SN
Thanks,
SN
And i'm also have to wait for a few months to race that beatyfull
thing because the weather here is very shitty right now
#1611
Originally posted by CraigH
Well it seems Jaco Nitro shoes wont fit? Any ideas on being able to use them?
Either change your wheel nut to use ordinary ones (that sucks I know) that do not have flanges or use a dremel to open the space wider to accomodate the Serpent wheel nut.
#1612
I went to LHS to see the 710 today. Serpent is right, its a completely different car!
Looks nice.... REALLY SWEET 4mm chassis!
From a quick glance, I notices more "square" shaped arms. The front upper arms are thinner, which is great since we had problems with top a-arms rubbing rims when turned too much...
The stiffners are thicker than before!!
THe weakest part might be the lower rear arm.
#1613
I believe the top A arms were never a problem on the 705 or the Impulse PRO. I think you're referring to the steering knuckles. The steering knuckles on the 710 is the same optional FC steering knuckles that you mount on the 705.
I've mentioned this before that the FC steering blocks (710 front steering blocks) will give better clearance for different types of rims.
Anyway, didn't you get Mark's D1? Where are the photos?
#1614
I guess he's referring to the side stiffeners.
They aare mounted in a better way as well. Instead of centering on a countersunk screw, they center on a notch on the bulkheads. That way the stiffness is improved and the plates will no longer move during a crash tweaking the chassis.
I'd like a car of my own thank you!
I have to wait until all you guys have yours and see if one is left for me.....
#1615
Really? But what's the hurry? Does not make a difference if you have to wait since you can only play after 3 to 4 months down the road, right?
#1618
Originally posted by sungtaz
705 Conversion Full Set Comming Soon
WOW............................................... .....
Looks sleak.
Who is making that set? Where and how much?
#1619
#1620
sorry if this is old news.. but i found these pics from another forum..
http://www.futbol-total.com/imagenes...o/dscn1523.jpg
http://www.futbol-total.com/imagenes...o/DSCN1522.JPG
http://www.futbol-total.com/imagenes...o/DSCN1521.JPG
http://www.futbol-total.com/imagenes...o/DSCN1520.JPG
http://www.futbol-total.com/imagenes...o/DSCN1519.JPG
http://www.futbol-total.com/imagenes...o/dscn1524.jpg
