Serpent 710
#2403
Sorry this is off topic guys, but this is where all the action is.
I've just received my 1st set of foams for the Impulse but when mounting the 30mm on the rear the head of the shock retaining screw binds on the inside of the rim, the 26mm front rims bind on the steering levers.
For info the wheels are Arrows, 0 offset, and I'm using the original alloy wheel hexes.
Can anyone offer any advice.
#2404
Standard on 705,710.
Part# 1255 grub screw x2
1650 Ball x2
http://www.mytsn.com/publ/publ.asp?pid=9332&sn=7
#2405
the c clip on the 22t pulley prevent me from adjusting it, I guess with the brake pulley you shouldnt see the indention on the shaft that the grub screw is supposed to cover, so I moved it over to where I could no longer see that indention, so now theres still some play but very little, but the pulley at the end of the shaft is no longer flush with the bearing, theres about 1mm space between it but its no longer moving. I guess its OK, if anyone thinks otherwise please let me know.
#2406
Originally posted by InitialD
You ask me what kind of info I needed from Mark Green...
Those were the kind of infos I needed !
Thanks !
Thanks !
#2407
The ID of your rear foam wheels should ideally be 47 mm I think. UFRA and Ellergi foams are the ones to use.
Also when I put foams on my Pro, I had to use one of those hex inserts for the front wheels. You will then have the issue of track width to worry about.
Alternatively, use only foam tyres that have the right offsets for the front. Changing over to the FC steering block solve the issue once and for all though.
#2408
Originally posted by ammdrew
check your shock lengths.. make sure they are the same. the only way to have less droop after instaling shocks is if one is shorter than the droop allows, must have a lot of droop to allow that though.. are you at 7 above chassis or below?
#2409
Diesel you need to update the mount on the shock to the ball and grub screw.
1650 Ball x2
1650 Ball x2
Mark, Pacman is right. The other way for the rear is to move over the lower shock mount onto the rear lower arms. I don't the part numbers but some of the newer arms released already had holes in them for the mounting grubscrews.
#2411
#2412
Just a side note, I did not find any rubbing on the steering linkage or on the steering knuckles with the 710. This is with Speedmind tires which on the 705, it does.
#2415
and the other side..
the pipe is on for weight and setup only, justa old tp045 i had laying around, and the tire size is were i expect i will be running in florida, as it is were i ended last year.. so 58- 60mm will be my start point with a 57mm expected end point after mains...
