Serpent 710
#3121
Originally posted by cyba888
But what about just the rear toe in adjustment? How should I set it up? Should I have it setup with 0 degree or with some negative toe in which is pointed inwards?
You can download the setup book from mytsn.
#3122
Initial rear toe-in setting is really whatever suits your specific driving style. Most people like 2 or 2.5 deg of toe-in whereas I will sometimes run as little as 1deg on some tracks to get the rear round faster.
The less toe-in you have the less stable the car will be for control. So I would suggest starting at 2deg and then adjusting it whichever way you need to suit
#3124
Originally posted by Diesel Racer
Check out Model Tech they do Ceramic Nitride Diff balls which should sort you out.
http://www.modeltech.co.uk/
#3126
Originally posted by baller360
initiald where can I find a serpent 710 on the internet for about $359.00 or less or anywhere I can get it for a good price with out having to pay $30.00 for shipping and handling like at rc mushrooms.
If you can find the 710 at $359 or less, get it even at $30 shipping. The rumour is that the price will go up as the Euro strengthens.
Know that those poor snakes in the UK are having to pay anything between GBP 345 to 390!
#3128
#3129
Originally posted by chachi
new problem....I am using a JR XR3 radio and receiver. is there any way to make the receiver fit into the receiver tray/box or is it only designed for micro-receivers?
#3131
I live in miami and at this site www.sslorder.com I can get it for $369.99 but there was this other site I seen that was selling it for $359.00 but I can't remember what site it was. btw the price is really going up now? becuase if it is it will be a good investment!
#3134
Here's a little tid-bit to share. I have long favored the disc wheels over the spoked ones, because they bend, and rarely break. With these Serpent wheel nuts, they are very bend resistant. BUT, (there's always a BUT), The off set is NOT the same as the spoked wheels. There is barely clearance between the dish wheels and the arm of the steering block, but perhaps 0.5 to 1 mm clearance with the spoked wheels.
#3135
It IS good investment sooooo go get a few!
