Old 05-17-2004, 01:27 AM   #10621
Schrijver99's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Charging batteries
Originally posted by InitialD
Interesting ! 220/240 should not be a problem right?
Are you sure rest of EU is 220? I checked and Germany and UK was 230... Malaysia is 240. NZ is 230.
The Netherlands has also 230 volt
Schrijver99 is offline   Reply With Quote
Old 05-17-2004, 01:27 AM   #10622
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Default Re: Re: Re: Bag 14
Originally posted by PSI Racing
Why don't you contact your nearest Serpent distributor, and ask for the missing parts?
Serpent is usually good at replacing missing parts.
I think World Model CO. LTD. is the distributor for the Philippines.
[email protected]
JUST GOT MY MISSING PARTS FROM OUR LHS BAG #14 CONTAINS ALL THE GRAPHITE PARTS AND YOU ARE RIGHT PSI Racing SERPENT IS GOOD IN REPLACING MISSING PARTS NOW I CAN REALLY FINISH BUILDING MY 710 THANKS GUYS.............
buboy28 is offline   Reply With Quote
Old 05-17-2004, 01:34 AM   #10623
InitialD's Avatar
Default Re: Re: Re: Re: Bag 14
GO ! GO ! GO !
Old 05-17-2004, 01:44 AM   #10624
BaxterC's Avatar
Default Re: Re: BaxterC
Originally posted by Marcos.S710
hey chris this is a picture of Fullthrottel track with the small track layout (for the pre-worlds)
HEY... Now that looks good. Sorry for the late reply... I have been shuffled around a bit at work and have still not finished setting up my PC. how are things on that side... My car is complete, I have got a battery for my starter but I have as yet not got a charger for it, wanted to run this weekend, but could not, all is well otherwise. I wanted to run on the track. I LOVE MY CAR!!!
BaxterC is offline   Reply With Quote
Old 05-17-2004, 02:09 AM   #10625
BaxterC's Avatar
Guess what... I got all my missing parts on Saturday... WOW that was fast. I also got my stuff from RCCarinternational... I have completed the car. One thing I wanted to cnkow, how do you set the ride height on the car, I have set the up-stops, the down-stops and all that, I am able to set it with the shocks, (threaded bits) but then to measuse it with the hudy ride height guage is a little hear raising as the chassis has a bevel which makes for a dificult one to see the guage. Does anyone have a tip for this?
Marcos, How is the house coming along? How did the meeting go last week?
Old 05-17-2004, 02:23 AM   #10626
InitialD's Avatar
Cool.
How do you mean you set the up-stops and downstops by using the shocks?
Did you not use the H11 grub screws on the upper bumper plate as in Step 1.7 (page 6) of the manual to set the front droop or the H12 grub screws in the rear bottom arms as in Step 3.5 (page 12) to set the rear droop? Up-stops usually not required or not set.
Old 05-17-2004, 02:24 AM   #10627
Sow&Steady's Avatar
BacterC, I normally use the Hudy gauge of course but now with the 710 I have the same problem as you.
So ... glue a couple of coins together. Make sets for 6.5, 7, 7.5 mm or whatever you desire and use them directly under the chassis.
Simple, works and extremely fast to use during the rush of a race!
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 05-17-2004, 02:31 AM   #10628
BaxterC's Avatar
Originally posted by SupermaxxRich
Nobody going to give my question a try??
Where to put the fuel tubing... in the drive ball cups and the driven ball cups , short little pieces will do, I found that the cups have little holes at the ends and the tubing fits into them nicely. so they can be a little longer, but they stay, and do not unbalance the cups as much as a little piece. I will try to show you at a later stage.
Old 05-17-2004, 02:32 AM   #10629
InitialD's Avatar
So now I know your trick ! I'll steal the coins from you on your pit table the next time.
Old 05-17-2004, 02:32 AM   #10630
BaxterC's Avatar
Default Re: Servicing metal shielded bearing.
Originally posted by markp27
Related to my bearing failure, does anyone know how to service metal shielded bearings.
Fortunately I have a couple of old centax shielded bearings which I can put in my 710, but one is quite gritty. I've cleaned it in degreaser and as I can't open the bearing, I've simply soaked it in serpent bearing oil. Seems nice and smooth now, but is there a better solution?
I think this would be the best as metal shielded bearings are a little bit tricky. if it is smooth, you should be ok.
Old 05-17-2004, 02:46 AM   #10631
BaxterC's Avatar
Cool.
Sorry D...
My fault, I meant I have setup the up stops and down stops, then set the ride height withthe shocks... not the up and down stops withthe shocks sorry.
Old 05-17-2004, 02:49 AM   #10632
BaxterC's Avatar
Thank you... GREAT Tip...
Has anyone given the 'Non-melting Grease' from Spanjaard a try...? I have used it on my diff and my thrust bearings, is soooo smooth and is sticky as anything. AND it does not have MUGEN on it.
Old 05-17-2004, 02:52 AM   #10633
Pyramid's Avatar
I think the snake bite you hard
Pyramid is offline   Reply With Quote
Old 05-17-2004, 02:56 AM   #10634
This is not happening! ok'D' now i know you know more about the 710 than anybody, but now you
know more about NZ than i do!!!!!!
Brett.w is offline   Reply With Quote
Old 05-17-2004, 03:01 AM   #10635
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Charging batteries
Naaah... It's the RING I tell you.
