Like Tree352Likes
NOVAROSSI Engine thread....
Old 09-10-2020 | 01:02 PM
  #10726
Originally Posted by Galatians2 20
I bought my Rolling from this seller and he ships very fast.
https://www.ebay.com/itm/Novarossi-Rolling/202632379080
Cheers mate for the link.
Burty.
burty is offline
Old 09-10-2020 | 01:45 PM
  #10727
Originally Posted by outcast32
I got a Rolling from the same eBay vendor and his shipping was fast. I should get another one before they are all gone. If you read the on road Novarossi thread Someone mentions that Novarossi sold a lot of their machinery and if that’s true I don’t see them ever opening back up.
This is horrible news for me to read:-(
Werty Yui is offline
Old 09-10-2020 | 02:31 PM
  #10728
Roelof's Avatar
Where did you read "a lot"?
All we know Fantini has bought some machines and now it seems he is able to run his own production.
Roelof is offline
Old 09-10-2020 | 03:44 PM
  #10729
I have to go back and see where I read it but I thought someone said they sold 80 percent of their machines.
outcast32 is offline
Old 09-28-2020 | 10:58 AM
  #10730
petersen114's Avatar
I have a Mantra laying around w/ only about a quart through it so it is in need of being finished breaking in. I don't do buggy any longer and am only doing truggy. My question is would this engine be fine for the heavier truggy?
petersen114 is offline
Old 09-29-2020 | 01:07 AM
  #10731
Galatians2 20's Avatar
I’m running a Mantra in buggy and it’s a great engine with good power. I think you should be fine with it in truggy with the right pipe combo, I’ve tried a few in buggy and engine definitely reacts to pipe/header change.
I used to have the Nova BF21 limited 3 port back in the day and put it in truggy and it was fine. I wasn’t racing yet and had just begun to hit a smaller track but cleared all the jumps and moved truggy around no problem.
I share that bc the Mantra is better and has More power plus truggys now are better then 9 yrs ago so just sharing why I think you’ll be fine; you might lack a little in truggy on a bigger track (keyword is might). I would say go with a 7mm Venturi or larger
if you want. Might lose a little on fuel mileage (I’m running 6mm in buggy) and good pipe combo.
I would say to try 41001, 41005, or 41031 for header. Pipe I would say probably 2096, 9853 or maybe 9886. 9901 or 2135 are good but I think would lack for that engine in truggy.
When I put the 41001 header on with 2135 pipe it had too much torque for me in buggy.
The 9853 pipe is a better low/mid pipe so I would say the 41001/9853 combo would be a good place to start for truggy.
Hope this helps a little, good luck with testing.
petersen114 likes this.
Galatians2 20 is offline
Old 09-29-2020 | 03:27 AM
  #10732
i've got a 28-8 that i have in my basher nt48.3 chassis.
i think i got a little anxious and ran it hard a bit to early with some questionable fuel. led to some detonation.
Novarossi kicked back my order for a rebuild basically saying they haven't gotten any parts in forever like mentioned in this thread.
is everyone having decent luck with the ct06 plug or are they finding it too hot?
ill be switching to fresh bones 30/8 and flush needles and starting over
the reason i believe the fuel was most of the problem is that it was older S&W which i believe was 25/12. It was in the squirt bottle for longer then i had thought so im assuming it was real low nitro high oil which got the motor super hot/lean on the top end causing the detonation.
The motor idles for days and low end is fine.
ray4624 is offline
Old 09-29-2020 | 05:44 AM
  #10733
Thanks. I have a 2096 and a 9901 for pipes. and a 41021 for a header. I might be able to come up with a 41031 header.
Old 09-29-2020 | 06:32 AM
  #10734
I’ve ran S&W 30/9 race blend in novas and other engines always ran great with ct06 plug. 12 is a lot of oil but maybe you were running to lean or it’s not shimmed right for that fuel.
jersey is offline
Old 09-29-2020 | 06:39 AM
  #10735
probably a combination of all the above,
hopefully the reset of settings helps get me to a base line again.
im going to check the pinch when warm to see if ive still got some break in to do.
i heard the detonation and the plug died so im assuming it was a lean issue. Not enough nitro for where i was at.
stock shims as well for now
ray4624 is offline
Old 10-03-2020 | 07:13 PM
  #10736
I’ve got a Novarossi 28-7 with a pull start. Can I delete the pull start and put a regular back plate on it? I’ve seen other engines on YouTube get the pull start deleted like the lrp 32 and thought I could do it with the Novarossi 28-7 but wasn’t sure. I did a search but couldn’t find anything. Thanks for any help.
Old 10-04-2020 | 12:30 AM
  #10737
Roelof's Avatar
You need to get a backplate of a non pullstart engine and grind off the pullstart pin of the crankpin.
J.Whiting likes this.
Roelof is offline
Old 10-04-2020 | 07:55 AM
  #10738
Thank you. I’ve been looking for a back plate with no luck. Thanks again for your help
Old 10-06-2020 | 07:28 AM
  #10739
you can email AMR
they will make you a backplate for that motor but only if you use their mod service.
going through the same thing with my 28-8
ray4624 is offline
Old 10-18-2020 | 12:04 PM
  #10740
Anyone hear any new news on Novarossi's current status?
