Like Tree352Likes
NOVAROSSI Engine thread....
Old 08-04-2020 | 05:58 AM
  #10696
Tipos's Avatar
Any help guys? , I need to order it as soon as possible, to break in it before next race
Tipos is offline
Old 08-04-2020 | 06:08 AM
  #10697
kgombe's Avatar
I actually use the plus 4 line of engines with the 9901/ 021 header combo. using these for the last 6 years or more..
kgombe is offline
Old 08-04-2020 | 06:15 AM
  #10698
egobrkr's Avatar
I like my Rolling in buggy. It has done well on all types of tracks
egobrkr is offline
Old 08-04-2020 | 08:23 AM
  #10699
HaulinBass's Avatar
well my hacked up karma did me well last weekend. i drove like a donkey and missed the bump but still had fastest lap,fastest top 5,10, and 15 and fastest top 3 consecutive ran an easy 9 minute pit(came in early around 5:50 in) missed the bump by ten seconds.came off the track at 220 when it was 30C outside.
HaulinBass is offline
Old 08-06-2020 | 04:10 PM
  #10700
I am hoping someone can help me out here. I purchased a new Rolling and had it broken in by AMR. After running a few tanks of fuel through it and having it run a little odd, I noticed that I had a fuel leak at the inlet of the carb. My inlet/HSN was tight and I wasnt sure how to stop the leak. I tried putting on a needle from another carb, but the engine was still not running right (didnt run it long enough to see if it was leaking). I ordered new washers for the inlet, but I wanted to ask if there is anything else I can do to ensure the carb will seal?
Just to be thorough here, when I say the engine wasnt running right I mean it was bogging on the bottom. It would idle great, and it would rip up top, but it had no bottom end. Sounded like the engine was either really lean when I got on the gas, or the clutch was bad. I changed the clutch shoes, springs, and bearings and tried to tune the LSN, but nothing had any effect. I ran 2 qualifiers with it, and the engine would run good for about 3 mins and then start to bog. After those 2 qualifiers I changed the inlet/HSN needle and it never ran good for any period of time.
IOP_Racer is offline
Old 08-06-2020 | 04:32 PM
  #10701
HaulinBass's Avatar
does the LSN bind in mid speed needle/spraybar at all? my newest three needle carb the mid must have been poorly machined the long needle is tight at closed(get similiar issue to what you describe). with the short lsn it just dumps the fuel at idle as it fits so loose in the mid/spraybar. IMO that 067/mito carb is garbage for an offroad motor, the two needle 069 carb is the very best nova offroad carb.im lucky i have a few spares but ive never had good luck with that three needle.
Old 08-07-2020 | 01:22 PM
  #10702
The Rolling has the 069 carb on it, so it does not have the problem you are referring too. I appreciate the input though.
Old 08-17-2020 | 08:04 PM
  #10703
Galatians2 20's Avatar
Do I have to get a new cooling head? Can I leave like this or maybe even cut off the rest of the top fin?
this happened at some point in my main on Saturday. Was a cooler night and came off the track temping at 215*. On hot days I’ve been in the 240-250 range. Let me know your opinions and knowledge on this.
Galatians2 20 is offline
Old 08-18-2020 | 10:21 AM
  #10704
Chad Millikan's Avatar
I'd say get a new one. Gunna hurt someone, better cooling, better looks
Galatians2 20 likes this.
Chad Millikan is offline
Old 08-20-2020 | 10:40 AM
  #10705
Hey guys,
does anybody know this engine? ISON 21 DLC
https://www.ebay.de/itm/Novarossi-IS...f196%7Ciid%3A1
Is it an onroad engine or is it for rally game? The cooling head looks more like a gt engine. Can this engine be used to power a buggy?
The prize tag seems to good to be true...
Andreas
andreas78 is offline
Old 08-20-2020 | 01:20 PM
  #10706
Cant drive's Avatar
Originally Posted by andreas78
Hey guys,
Andreas
it is an onroad .21 ison with dlc crank (I have one). Comes with ceramic rear bearing and ct8 plug. The sleeve is the same as the regular ison .21 and has a slightly different carb.
Werty Yui likes this.
Cant drive is offline
Old 08-20-2020 | 04:54 PM
  #10707
Thank you, that was a big help.
Old 08-23-2020 | 08:50 PM
  #10708
Yelreppa's Avatar
Default Bt4 Base settings help
My friends bt4 tune is all over the place
Hard to start
Once running just keeps stalling
Bogs and stalls after half a tank on throttle
​​New glow plug/fuel lines
Alot of smoke
He's at the point of packing in! And I've only been running nitro for 5 months so need more help on issue?
To get him back to base settings is it best to turn HSN to flush
And the LSN is 1 turn in from flush then he can start again?
From there I can help him fine tune the HSN and maybe get some where then help needed
Yelreppa is offline
Old 08-24-2020 | 08:32 AM
  #10709
HaulinBass's Avatar
is the motor fine internally? clutch good? whats the glowplug look like? an engine stalling on throttle "usually" only happens in a lean condition, a rich engine will gurgle and blubber when you get on throttle and may stall but will be on the initial pull after loading up with fuel off throttle, if you pull 20-50 feet out of the corner and then stall its probably lean.
an engine that is wore out internally, typically a streached rod can cause similar issues but your glowplug coils will start to look pushed in and the engine will have a noticable bit of play when it gets into compression.
if thats not the issue pull the carb apart and make sure its good and clean internally. set the high speed 2.75 turns from closed, start with the low speed 5 turns out from closed(pull the carb slide open while you do this) and slowly work your way leaner from there.
Yelreppa and Werty Yui like this.
Old 08-30-2020 | 12:15 PM
  #10710
Does anyone know anything about the Novarossi RS 8 crono or the plus 21-8t. I did some searching and didn’t come up with anything on the plus 21-8t and I saw where someone said the crono was a fast engine. I wanted to buy another two engines and found these at decent prices or I may just get a Rolling. They would be going in a truggy and buggy for bashing. Any information would be helpful. Thanks
outcast32 is offline
