Like Tree352Likes
NOVAROSSI Engine thread....
Old 04-30-2020 | 04:07 AM
  #10546
Originally Posted by J.Whiting
i ran the rolling in my truggy and really like it.. both are long stroke engines with very similar specs. either will be just fine
I am wondering why the rolling says tuned crankshaft but the mito is more expensive. Strange.
ohiofordfan is offline
Old 04-30-2020 | 06:46 AM
  #10547
Galatians2 20's Avatar
Is the mito 7 you’re looking at with ceramic bearings? That would definitely increase price.
I also have a rolling and am very happy with it. Even during breakin and initial tuning plenty of power while rich.
Don’t know first hand but I’ve also read that the mito line didn’t have the life span of most Nova engines.
If you’re looking to buy a new Nova check out Cosmopro on eBay. He sells them at great prices and ships super fast.
I ordered both my Rolling and Mantra from him and got each of them 2 days after sale.
jersey likes this.
Galatians2 20 is offline
Old 04-30-2020 | 07:04 AM
  #10548
I am also running Virtus and rolling, basically the same engine with different bearings.
I am very happy with them, great bottom, great top! Overall perfect. I have 3x virtus and 3x rolling that I run them all in truggies!
Pedro Jesus likes this.
GeorgeCk is offline
Old 04-30-2020 | 01:55 PM
  #10549
All steel bearings, not a fan of ceramic.
Galatians2 20 likes this.
Old 05-03-2020 | 11:08 AM
  #10550
Hi guys, anyone knows why the mantra is out of production?
victor_leon is offline
Old 05-04-2020 | 08:47 AM
  #10551
cbh148's Avatar
Got my new Bonito broken in for the most part. Installed a Buku front bearing cap on the engine right out of the box. Had some difficulty with it priming, and before I figured out what it was, I removed the 7.5mm venturi that came in the carb to set the idle gap to 0.6mm and never put it back in. The fuel supply issue wound up being the dark Tekno fuel line included in the NB48 2.0 kit. Robbed the thicker light color line from my old Losi RTR and now it primes up and pulls fuel like it should.
The Bonito screams. I expected it to be about the same power as my old P5 since I'm using the same Dynamite 053MR pipe/header setup that I used on that P5, but it's significantly better power all around with the Bonito. Haven't timed it for fuel mileage and don't know how much it'll change power/mileage if I put the 7.5mm venturi back in.
cbh148 is offline
Old 05-04-2020 | 12:55 PM
  #10552
Have no clue why bc this little thing screams.
If you want to buy one I think the guy I got mine from on eBay still has. They come new in box straight from Italy. Great prices and super fast shipping.
I have probably close to a gallon on mine now with 4 days of track time and one track has a straight close to 100’ long and she screams down it and doesn’t even sound like she’s hitting peak power until the last 10’.
I think I have to lean her out more. She’s creating amazing power low and top but I did a few full throttle rips away from me and back for about 40’-50’ each way like 5-6 times and checked temp and it was only at about 180*F and it was 70*F sunny
jersey likes this.
Old 05-04-2020 | 03:41 PM
  #10553
pballer2777's Avatar
There was a 2020 version listed. The eBay seller that had them is out of stock on a lot of engines. Hopefully he will get more soon.
pballer2777 is offline
Old 05-04-2020 | 04:29 PM
  #10554
jpz_67's Avatar
Hello all, I have a rolling in my buggy with a 41021/9901. It actually runs really good. Good bottom, good top, but it seems a little thirsty. Haven't timed it, I'm guessing it's around 9 minutes and then dry.
My question is has anyone tried a 41021/2135 on the rolling?
jpz_67 is offline
Old 05-04-2020 | 04:57 PM
  #10555
egobrkr's Avatar
what Venturi are you using? My rolling with 41021/9853 6.5 Venturi can do 10mins every time I hit the track
egobrkr is offline
Old 05-04-2020 | 07:37 PM
  #10556
jpz_67's Avatar
I have a 7mm Venturi, I wanted to let it eat lol. The track had a lot of wheel spin and is pretty high speed. Lots of full throttle. I am sure that is a factor. I plan on going down to a 6.5 or 6 as the motor has ample power in buggy.
​​​​​​I just have a 2135 and will end up trying it. Curious on pro's/cons. Fun motor for sure .
jpz_67 is offline
Old 05-04-2020 | 07:41 PM
  #10557
jpz_67's Avatar
My guess is to make you buy a mephisto if you want the square stroke novarossi. They are almost the same engine. The difference that I see is dlc crank, 3 needle carb, and cooling head on the mephisto .
jpz_67 is offline
Old 05-05-2020 | 05:05 PM
  #10558
Thanks all you guys for the answers.
jpz_67, are there any advantage on square stroke engines over the long ones?
Old 05-05-2020 | 09:51 PM
  #10559
jpz_67's Avatar
Absolutely there is. I ran a lot of engines over the years. Square stroke engines are so smooth and linear.
I can drive better when I have more control over my buggy. A smooth power band makes this much easier.
The rolling was not ballistic compared the the mantra but it did have more wheel spin and required easier throttle inputs.
Of course it did have more power everywhere. I mainly bought it for when I go to a larger track or when I want a bigger smile on my face.
jpz_67 is offline
Old 05-06-2020 | 03:47 PM
  #10560
Default Novarossi bx3
I’m breaking the engine and seems to have plenty of power for a buggy I have ran some novarossi in the past and liked them any body have any thoughts on this engine
Venomracer1988 is offline
