NOVAROSSI Engine thread....
#3048
square stroke means the bore and stroke are the same number, in this case 16.42mm bore X 16.42mm stroke (ie 16.42X16.42 or 16.42 squared)
the RB S7s and S9s(also "Worlds" editions), along with a few others were all square stroke.
the newer RBs are all long stroke, 16.22mm bore X 16.80mm stroke
#3049
#3050
. It's similar in lenght with 41021 but has a smaller bend. 41020 is longer than the two.
#3051
#3053
.6mm idle gap, 3.5 from closed on the top, 5 from closed on the bottom. be sure to remove the venturi when you set the idle gap
#3054
#3055
when you start to drive it around, be nice and smooth on the trigger, no full pulls for about 6 tanks of driving. Don't let it gain to many rpms. After about tank 8 you can ease into full throttle but only for a second. Make sure it stays between 200 and 210.
#3058
I would say C6G. It's what I've run in most my Nova Rossi with a std head button.
http://www.novarossi.it/eng/products...x.php?plug=ssu
#3059
Can anyone tell me if there are any issues with grinding away the front of the engine mount tabs? Just need to take a bit out to run the engine forward in my JQ buggy and want to be sure before I attack it with a dremmel.
352Likes
