Like Tree352Likes
NOVAROSSI Engine thread....
Old 05-28-2012 | 08:49 AM
  #2896
aznitronut's Avatar
Originally Posted by Chad Millikan
A while back on this thread, I read that the RB ones work for the back plate.
RB's are all slotted screws, just a few use cap head. Mostly japanese engine use cap head screws, that I have noticed.
aznitronut is offline
Old 05-28-2012 | 08:51 AM
  #2897
aznitronut's Avatar
James, get better screw drivers and you won't mess up the screw heads so badly.
Old 05-28-2012 | 09:15 AM
  #2898
Jaz240's Avatar
I have 40 different screwdrivers Tony and I even went as far as finding the perfect fit and then grinding down the edges so the driver fits into the holes in the cooling head. The design of the screws are just so bad that the driver slips loose before I can apply any torque. The P5 has a large O-ring type squish band under the head button that gets torn up fast and needs to be replaced and my engine needs a new front bearing. FYI the Werks head screws fit perfect and they are 3mm cap head hex so they will be very difficult to strip out if anyone is interested.
Jaz240 is offline
Old 05-28-2012 | 09:17 AM
  #2899
megasaxon's Avatar
RB's are made by novarossi, at least the good ones...
those hafta be 3.5mm thread with 3mm head correct?
megasaxon is offline
Old 05-28-2012 | 09:20 AM
  #2900
aznitronut's Avatar
Correct, as far as I know, the Nova's use slotted screws,
Old 05-28-2012 | 09:25 AM
  #2901
aznitronut's Avatar
How is the O-ring getting torn up so quickly? If its squished down, nothing is moving to tear it up. The 21-4 has the same type of O-ring thing.
Old 05-28-2012 | 09:29 AM
  #2902
Jaz240's Avatar
As soon as you tighten it down it gets chewed up. It's not a good fit into the button and the button tears it up when you tighten the bolts
Jaz240 is offline
Old 05-28-2012 | 09:30 AM
  #2903
Jaz240's Avatar
I have not measured them yet. They are slightly shorter but I think they will work fine.
Jaz240 is offline
Old 05-28-2012 | 09:40 AM
  #2904
aznitronut's Avatar
The newer RBs with the Low profile head ( LG ) uses shorter head screws, the LG head is made with 2 cooling fins sitting lower over the engine case. If the head screws are shorter, its easier to strip out the threads on ths engine case if they are to short
Old 05-28-2012 | 09:42 AM
  #2905
rider313's Avatar
I also just used screws off a old dead engine I had. The head screws were two threads shorter but that shouldn't matter. Idk what nova was thinking, let's put a shallow slot flat blade screw for the head bolts. Much easier to torque with the allen heads.
rider313 is offline
Old 05-28-2012 | 09:56 AM
  #2906
jnorwood_losi's Avatar
http://www.amainhobbies.com/product_...si-Engine-Head
This Hudy screwdriver is made for the Nova's, it fits into the head PERFECT and I have never had a issue
jnorwood_losi is offline
Old 05-28-2012 | 09:58 AM
  #2907
megasaxon's Avatar
i disagree, as soon as you start to wear the allen head out, good luck getting it out of the case. I use a nice stanley screwdriver with the tip dremeled just a touch to fit in the head a little better and havent had an issue and i take my engines apart regularly
Old 05-28-2012 | 10:49 AM
  #2908
houston's Avatar
Flathead screws: reasoning , harder to apply too much torque that will warp the block
James : if you are tearing up the oring its because your shimming is lower than novarossi recommended .65mm is the very lowest i will shim a novarossi , .60mm is ok but ......
Just leave the oring out , wont harm anything
houston is offline
Old 05-28-2012 | 11:15 AM
  #2909
Jaz240's Avatar
However Neal sends em out is how its shimmed..I will measure when I get back home..The flathead screw now makes sense But I still hate them..I have never in my life heard of anyone warping their blocks with metric hex head cooling head screws but I guess anything is possible.....
Jaz240 is offline
Old 05-28-2012 | 12:28 PM
  #2910
bigjayjay1's Avatar
I agree with James hex hex way better screws with slots equals problems. I don't run the oring on my cre P5 -head button
bigjayjay1 is offline
