NOVAROSSI Engine thread....
#2146
#2147
ok novarossi guys... I want to order a motor asap but am torn between the plus 4 "tuned" for 239.99 on a amain or the plus 4 btta for 284.99 on a main. besides the new head design are there any other benefits of getting the new btta motor? is it worth the extra 45 bucks? thanks
#2148
Specifications:
Displacement: 3.5cc
Max. power: 2.60 hp
R.P.M (Max. power): 32,000
Practical RPM Range: 6,000-38,000
Crankshaft: Turbo SG
Carburetor Material: Plastic
Carburetor Type: Slide
Carburetor Adjustment: Single
Glow Plug: Standard
Exhaust: Rear
#2149
[QUOTE=houston;10330680]plus 21-4buggy
Specifications:
Displacement: 3.5cc
Max. power: 2.60 hp
Glow Plug: Standard
Exhaust: Rear[/QUOT
Thanks, I'm a little confused because in the specs it says standard plug as you posted but in the description on a mains site it says "tuned" (turbo plug)
Specifications:
Displacement: 3.5cc
Max. power: 2.60 hp
Glow Plug: Standard
Exhaust: Rear[/QUOT
#2150
[QUOTE=function>form;10331139]
you will get the turbo head , I did the same and they sent me a standard head so I hit them up and they forwarded me a turbo head button at no charge, give the 21-4 a go mine is awesome in the truggy unreal runtime
plus 21-4buggy
Specifications:
Displacement: 3.5cc
Max. power: 2.60 hp
Glow Plug: Standard
Exhaust: Rear[/QUOT
Specifications:
Displacement: 3.5cc
Max. power: 2.60 hp
Glow Plug: Standard
Exhaust: Rear[/QUOT
#2151
What's the overall best engine for a buggy in the nova line of engines, Ive been reading through the forum and I've seen that the plus-4 is very popular. My question is why? Why not the bonito? How do both compare as far as fuel economy, bottom end and top end?
#2152
Plus 4 very controlable power
Aussies1129- that is kinda weird that it has the description of a plus 21-4buggy which is standard but says turbo in the header description
#2153
The +4 is dead smooth and applies it's power very well in today's lightweight buggies. Overall, it's hard to argue with.
For *most* tracks, the Bonito doesn't really have a chance to stretch it's legs.
The X7 fills the void between the two and offers a broader range of flexibility, with slightly more midrange torque than the 4, without the "soft" bottom of the Bonito.
#2154
Overall, the +4 and/or the X7 will work perfectly well.
thnx
#2155
The +4 is the *easiest* to achieve big runtimes with.
However, the X7 and Bonito can match it with a skilled driver and minimal effort; but if you're ham-fisted (triggered) on the throttle, stick with the 4.
The Bonito isn't *too* soft on a big track. Small tracks, yes I'd say so. But you'll find plenty of other opinions as well.
#2157
#2158
Any suggestion on getting the little grub screw that determines the ball linkgae rotation out? The head has rounded out enough I cant get a grab on it with the driver. Usually would use dremmel etc, but a bit on the small side.
Hoping to race tomorrow, but need to get this thing rotated.
The screw on this is what I am talking about.
http://www.amainhobbies.com/product_...Ball-Linkage-1
#2159
i've been using a +4 that came with my *used* mbx6. despite it being 2nd hand, it has ran flawlessly.
just very recently, i was offered a good deal for another +4. it was too good to pass up. owner says it has got 3L under it, but it looks brand spanking new, if i have to say so myself.
UNFORTUNATELY .. engine had been left in the car in the garden shed for a number of months. when i pulled it apart, i can see what appears to be traces of rust developing (on the crank and inner bearing race), not a lot but noticable enough. what would be the best way to get rid of them?
- change every part that is rusted?
- run it as per normal .. will that "burn" up the rust?
- flood with ARO before running ... ?
any suggestions, pls? thanks in advance.
#2160
Quick question: I have an older REX P215RS (basically, an older version of the NR P5XLT afaik..), that was also modded from what I understand for more top end. I have a 9901/short header on it, and it's in my DM-1. The car has a nice top end with this engine and pipe, but lacks explosiveness. I know it's a .21 and so never will have the oomph of a .28. I was just wondering if it would be worth trying a Dynamite 053 on it? Otherwise I'm just thinking this car needs a .28... So anyway, how should a basic NR engine respond going from a 9901/short to an 053? Thanks.
352Likes
