NOVAROSSI Engine thread....
#650
I picked up RbMods 821b today for cheap. It looks to be in great condition, so should be fun to play with.
Due to it's age I can't seem to find too much info on it, so had a couple
questions:
- Glow plug recommendation with 30% (non-turbo head)
- Shimming with 30% (just wanted to check)
I was going to run it with 053 pipe I have laying around in a truggy.
Thanks...
questions:
Thanks...
#653
If you are gonna use it in truggy I would recommend a lil stiffer clutching a 7.5mm restrictor and a 9853ss/41021 type setup
#654
The flat piston is the older version, while the dished/domed piston is the newer version (as far as I know). Nova typically reserves dished pistons for their higher-end engines, since they require more machining and steps to produce. In theory the dished piston engine is their best version.
#656
is there parts avalible for this motor , is it a discontinued motor whats the best plug ,is there a turbo head conversion seems to be a good little back up motor still havnt finished breaking in i have a jp3 and 086 wich should i run
motor in ? n.21 r limited
#659
#660
352Likes
