NOVAROSSI Engine thread....
#665
The 9853 pipe works great in a truggy. I'm running a toro team in my buggy with the same pipe, but you might want to use the longer nova header in truggy, I geared my mbx6 up one tooth on a large track, from 13 to a 14 woooahhh. It was just perfect. Super powerband....
#666
ime currently breaking in my nova n21r limited motor and i am at a 3/4 gallon on it and its still very tight at top is this normal for novarossi i heard they are harder to run in than most motors i am heat cycling it at 215 to 225 is my temps when i check it
#667
If you're at 3/4 gal yeah you'll still feel pinch. I just broke in my FMS, it has a 'lil more than 1 gal and it still has a slight pinch, keep heat cycling it and run it some more you'll be ok. your temps look ok.
#668
this is my first nova breakin
#670
Recently i purchased a toro nero and it came with a novarossi pipe 9901 i think anyway i have this engine in my GS XUT truggy and no matter what i do i cant get to finish i 6 minute qualifier without running out of fuel it goes for like 5 minutes and thats it.
also it keeps wrecking clutch bearings within 15 minutes of run time and they are like bottom bearing is weled to the crankshaft .
this engine is really powerfull and absolutly flies but not sure what to do to get it better .
i know how to tune an engine reasnobly well and are stumped by it..
any help would be appreciated.
cheers
Dave
:fla ming:
cheers
Dave
:fla ming:
#671
cheers
Dave
:fla ming:
cheers
Dave
:fla ming:Sean
#672
i just barely at 3/4 gal on my toro nero team with 9853 pipe in my truggy and running at 200deg and slightly rich still i was able to get 9mins easy i run on a big track long straighaway once i do a race tune and get the 9901 pipe it should get 10+mins i hope
#673
cheers
Dave
:fla ming:
cheers
Dave
:fla ming:I have just ran in a new Toro and i also am finding the clutch bearings are a little tight on the crank shaft
,Dave
#674
#675
cheers
Dave
:fla ming:
cheers
Dave
:fla ming:
i personally have never had any issue of the such related to the engine . and btw , i ran an FMS HT this weekend with 9853ss/41021 , 7mm restrictor , byrons gen2 prodriver , geared at 13/50 in my st-rr and all i can say is it was a handful
in a fun way though
and i won the race
352Likes
