NOVAROSSI Engine thread....
#691
advfuel,
No, not good. Excessive crank pin wear. Along withThe conrod bushing likely worn an aprox same amount the fit is fair at best,in its outer limits now.
I think you would have had better breakin results on the ground, with very easy throttle atleast another 1/2 gallon.
Hope this helped
RayAracing
Hope this helped
RayAracing
Your right Ray, Its not good.
When running in my engines, I always use the bench. cover the head. The temps on this engine ranged between 90-105c during runin. To be honest, after 500ml the engine felt runin. At the 750ml, with the glow plug out it had no pinch at the top at all. I wasnt happy at that point but decided to put it in the car and take it to the local park and run some fuel through it and find a rich tune. The engine tuned OK and had plenty of power. Thats when I took it out this past weekand for a run at a race meet. The rest is history. its a bin job now. Even the head button is very very loose in liner which I dont like. Oh well as they say sh!t happens.
#692
Thanks ray
c( improper break in and not preheating before firing engine I have cranks on all types of engines that don't measure that small that have 6,7,8 gallons so this is by no means normal
Pm or email me if you have any Q's
Happy motorin',
Monty
#693
So you're saying after three litres of fuel your engine is in that bad of shape? The engine in question was an FMS right? That sounds pretty fgar fetched but not impossible by any means if a( your fuel was no good (seen tha) b(your air filter is no where near as good as you thought it was c( improper break in and not preheating before firing engine
Happy motorin',
Monty
Happy motorin',
Monty
You have PM Monty
#694
I have just run in my 1st Nova offroad engine, +21-7FMS. I ran it in on the breakin bench doing the heating up before start over the 1st Litre ETC.
The past weekand I ran its 1st race. I went thru around another Litre of fuel.
I just striped the engine as I do after every race meet to inspect bearings and rod. After I removed the back plate I noticed the rod had alot of slop on the crank pin. I removed the crank and measured the pin.
Pin @ TDC 4.81mm
Pin @ 3oclock 4.92mm
.10mm out of round
Whats your thoughts on this? To me its not good.
Pin @ TDC 4.81mm
.10mm out of round
#696
OK so my P5X ebmod busted a block this weekend, one of ears on the
block is cracked off. This was an 05 EbMod REX P5X that I got brand
new just a few months ago and only had 2.5 gallons on it.
First question, will a regular block work, or did EB used to make mods
to these blocks as well? Second Q, will a later gen P5 block work if
there wasnt mods made to the original? I figure the newest model P5
block wont work but maybe the gen just prior to this will. Any help
would be great as I really want to run this thing some more, I think
it was the fastest motor Ive ever had.
#697
#699
#700
Thanks man, from what I could tell when I first got it, the backplate looked untouched. A freind has a worn out newer gen P5 that I can take the block from so Im hoping it will be just that easy. That friggin sky launch at the hut must have done it. I guess Ill double it now.
#701
Hello I have a question about the Novarossi n21bf crank. Long story short, I snapped off the end of the crank when I was trying to get off the inner clutch bell bearing. The motor still has a lot of metal pinch and compression. Is it worth replacing the crank in it or just get rid of the motor?
Also I have tried doing a quick search for a new crank and all I'm coming up with is a crank for a Novarossi n21b. Is this the same? I think it is but want to make sure.
#702
man i love your sig... its really price-less
#703
just lmk if you need anything
352Likes
