Like Tree352Likes
NOVAROSSI Engine thread....
Old 08-22-2015 | 06:09 PM
  #8161
capcept's Avatar
Just wanted to do a follow up with you guys on my Roma.
i replaced the rear bearing and the front, the rear bearing was definitely shot. Engine runs so much smoother now.
But...
One thing i have noticed now is that the piston head is tapping the button head, this came about when i fired up the engine and was hearing a pinging.
So from what i have gathered from reading
1.) no shims or not enough, All 3 stock ones are in place. is a solution to add one more?
2.) connecting rod has stretch and needs to be replaced? not sure how to check this.
3.) having the sleeve pinched fixes this?
Any help would be great.
capcept is offline
Old 08-22-2015 | 07:44 PM
  #8162
cczjordan's Avatar
Try factory shimming, check exploded view, others nova .21 always .8mm!
Fix what is critical then only move from there
But...
cczjordan is offline
Old 08-22-2015 | 09:01 PM
  #8163
capcept's Avatar
It's currently at factory shim, .80.. What would cause the piston to lightly tap the button head... No sign of damage to the piston yet..
capcept is offline
Old 08-22-2015 | 10:07 PM
  #8164
cczjordan's Avatar
[QUOTE=capcept;14152937]It's currently at factory shim, .80.. What would cause the piston to lightly tap the button head... No sign of damage to the piston yet..[/QUOTE
I think either u need help or the engine need help, get someone to help u, this forum wont fix ur problem because .8mm head shim is perfectly correct
Old 08-23-2015 | 07:06 PM
  #8165
sn47som1's Avatar
compression loss making higher stroke maybe?
sn47som1 is offline
Old 08-23-2015 | 07:16 PM
  #8166
sn47som1's Avatar
Originally Posted by Jerm13
It was implied that there was a "way too" before the lean in that statement
haha I guess so!
sn47som1 is offline
Old 08-23-2015 | 07:17 PM
  #8167
sn47som1's Avatar
Originally Posted by cczjordan
I would recommend rex paloma, try it to believe
I hear it's a Bonito or the like?
sn47som1 is offline
Old 08-25-2015 | 01:58 AM
  #8168
cczjordan's Avatar
Close but not smooth i would say, maybe some gurus can give better explanation
Old 08-25-2015 | 02:49 AM
  #8169
any one tried a werks 2058 with the 41021 header looking at pipe combo for bonitto have the 9853 with 41021 header atm
geforce is offline
Old 08-25-2015 | 05:28 AM
  #8170
cczjordan's Avatar
I'm using 2096/41021 n like it but it is paloma, 9901 will have more aggressive bottom, is the werks 2058 same as hope/orion 2058?
Old 08-25-2015 | 05:57 AM
  #8171
beidle99's Avatar
Yes the Werks and the Orion are the same pipe. I liked the 2058 on my Plus 4, but I never tried it with a different header.
The 2058 falls in between the 9901 and 2096. little softer on bottom then 9901 and not quite the top end of the 2096.
beidle99 is offline
Old 08-25-2015 | 11:56 AM
  #8172
sn47som1's Avatar
Here is a vid of a Virtus (similar 7 port Nova like Bonito) with 41001 and 2058. Looks like a STOUT combo and I would def run it just to give you an idea. With 41021 it would be less aggressive on bottom and smoother on bottom. 41001 more aggressive and more top end.
https://www.youtube.com/watch?v=rQL4QsxSSBY
sn47som1 is offline
Old 08-25-2015 | 09:41 PM
  #8173
thats cool thanks for the video how are you finding the venturri's (carb inserts)
i have the nova 5.4 in it atm still breaking the bonitto in on rish setting
how does the 5.4 to 7mm feel?
geforce is offline
Old 08-25-2015 | 11:49 PM
  #8174
sn47som1's Avatar
I dont know... I never run below a 7mm. Most of the time I run 8mm or 7.5
sn47som1 is offline
Old 08-26-2015 | 12:20 AM
  #8175
question for you nitro heads is it true you get more bottom end from a smaller venturri and just sacrifice more top power
or is going from small venturri to say an 7 or 8mm give overall more power from bottom right through to top end?
bluexile67 is offline
