NOVAROSSI Engine thread....
#6664
#6665
#6667
#6669
personally I thought the 9853, 2084..41005 and 41021 all performed poorly on the stock Bonito.... We run on high grip and these combo's made the engine feel very soft..From every bit of testing I have done with the Bonito it prefers to have the shortest manifold possible, especially if you are wanting it to make good power with lots of snap....The longer the manifold the lazier the engine feels and responds....
note. Lower traction conditions can make the engines react differently...How early and how hard the engines are put under load can change how different pipes react and feel to throttle input....
on our track conditions there is no other combo worth running but a 9886/41001/41019 on a stock or modified Bonito...this combo gives the best bottom end kick with the largest overall powerband... SO if you are running on higher traction I wouldn't be looking at a 2084 or a 9853 or a long manifold...maybe its great for slick tracks, but for anything like what we have those combos are not that good.....The very first time I tested a Bonito it was on a 2084/41005 and my first thoughts were that no wonder nobody likes these engines as it had no pop whatsoever. But as soon as a 86 and short manifold were put on the engine woke right up with all kinds of bottom end power and snap.... true story !
#6670
#6672
My Novarossi pipes and headers look like crap. Is there a polish out there anyone can suggest from experience of making it "bling" like it did when it was new? Kinda bums me out lookin at it!
#6673
Hello! I use the Novarossi 2096 pipe with the 41029 (short manifold for Mugen) and 7,0 venturi in my Maxys Cinco BT. What will happen to the powerband if i change manifold to the 41001 manifold? The engine realy came alive when i changed venturi from 6,5-7,0. But for my local track i need some more power in the midrange powerband. When i come out from a pretty high speed turn i need to go to full throttle to clear a huge jump. But when i go to full throttle the power realy isnt there. I often land short.
#6674
I have had good luck with the crock pop with coolant to clean off all the crud from the pipes. I then use the abrasive side of a dish sponge and it gets them pretty good looking again. Not the exact same pop as a brand new pipe, but a good 90-95% of it back.
#6675
Yeah, I used to do that. I was hoping someone ran across a good polish and could save me time/money.
352Likes
