Like Tree352Likes
NOVAROSSI Engine thread....
Old 04-17-2014 | 08:11 AM
  #6646
Lille-bror's Avatar
Originally Posted by Greg B
Engines are too dang tight from the factory. Takes a good bit of time to get them broke in.
What the hlel: easy to keep the temp up during break in and after one liter of fuel you just need to run it a little rich on the top until she is ready for race tune
Lille-bror is offline
Old 04-17-2014 | 04:00 PM
  #6647
xc7's Avatar
xc7
Originally Posted by ABN Hoosier
Is yours the older version? The one on clockworks site looks like the older version.
Sorry for the delay, Yes ours is the new style. That was an old picture a few years ago. Here is a photo from today.
http://clockworkracingengines.com/content/nov37000
xc7 is offline
Old 04-17-2014 | 10:27 PM
  #6648
ABN Hoosier's Avatar
So, is the gun you sell on your site is exactly like this picture:
I wanna get one. Just wish there was more info on it. Does it leak, is there a oring rebuild kit like the losi gun, or maybe a video would be great. Let me know? Thanks
ABN Hoosier is offline
Old 04-18-2014 | 04:25 AM
  #6649
Does anybody run or have run the Romas. Just looking for a little feed back
bkuff-losi is offline
Old 04-18-2014 | 05:33 AM
  #6650
hookem34's Avatar
R/C Tech Elite Member
I have been running the "old" version for almost a year now. It has been flawless. It doesn't leak, but you do have to keep the nose of the gun pointing down when it's full. Otherwise, fuel will get into the pressure pipes (not sure what their technical name would be ) and leak out the front of the gun when you point it back down.
It is super high quality and works like a charm. Oh, and I bought it from Clockworks because those guys rock!
hookem34 is offline
Old 04-18-2014 | 05:40 AM
  #6651
scrapsz's Avatar
I ran the Roma for a few months last season with 9901SS/021 combo in 811T. Very good engine with surprisingly smooth powerband. Fuel economy on par with other 'big block' engines. Impressive top end...pulls strong.
scrapsz is offline
Old 04-18-2014 | 12:38 PM
  #6652
xc7's Avatar
xc7
Yes. The picture in my link I posted is from our stock.
xc7 is offline
Old 04-18-2014 | 10:49 PM
  #6653
hi guys. i have the following pipe and headers
9886 9901 and 9853. manifolds 41029 41021 and 41001
which combo do i run best with a virtus for overall performace? track is loose with a long back straight?
oggietiu is offline
Old 04-19-2014 | 05:12 AM
  #6654
dmartin's Avatar
Of those choices I would run the 9901/41021 unless you have a Mugen then run the 9901/41029. The 9886 is comes on like an on/off switch & the 9853 is not as smooth on the bottom so it would have problems in loose conditions. The 41001 is not as smooth in its power delivery and develops more torque so I would not recommend it over the other two headers. If you don't mind buying another pipe the 2096/41021 or 2096/41029 combos would be the optimum setup for that engine in those conditions.
dmartin is offline
Old 04-19-2014 | 07:31 AM
  #6655
merdith6's Avatar
Default well
I like the 9886 41001 combo on everything I've tried it on. Especially on larger tracks.
merdith6 is offline
Old 04-19-2014 | 07:32 AM
  #6656
beidle99's Avatar
41021/9901 combo would be your best bet. 41021 fits in the Mugen MBX7, the x6 required the 41029. I personally run the 41021/2096 combo. It provides a smooth, yet strong bottom and midrange and a much stronger top end then the 9901.
beidle99 is offline
Old 04-19-2014 | 09:43 AM
  #6657
scrapsz's Avatar
+1 beidle99's comment regarding the 9901/021 combo mainly because you said 'loose'. The Virtus should be plenty strong on top.
scrapsz is offline
Old 04-19-2014 | 11:20 AM
  #6658
houston's Avatar
For sure 9901ss/41021
houston is offline
Old 04-19-2014 | 05:06 PM
  #6659
I will buy it on payday, Monday.
Old 04-19-2014 | 08:15 PM
  #6660
dmartin's Avatar
I'm still sticking with my 2096/41021 as the best setup because it will smooth that engine out so it's great for loose conditions, give you better fuel economy than the others and still have lot's of top-end for that long straight.
dmartin is offline
