Like Tree352Likes
NOVAROSSI Engine thread....
Old 03-23-2014 | 05:32 PM
  #6496
Vinny Cancilla's Avatar
Originally Posted by Maximo
if you want it to make good performance try a 9886/41001..... then if you need to detune it run a 9901/41021 or a 2096/41021
What do you mean detune? Less power? More run time? Why do most of the pros that run the 4 port nova's use the 9901/41021? I would think they would benefit from more performance.
Vinny Cancilla is offline
Old 03-23-2014 | 06:25 PM
  #6497
Maximo's Avatar
They like the feel of the 9901/41021....its mellow and smooth....... however if someone wanted more kick and more RPM then the 9886 works well..it makes more juice, but is not as smooth........
Maximo is offline
Old 03-23-2014 | 10:48 PM
  #6498
Suspended
I was testing a few pipes with a few Nova off road engines and the Max Power 2018 on road pipe was definitely the pick of the bunch. The difference between this and the off road pipes was noticeable, tank time was very similar too, only a 10 second difference.
The engine breathed so much better, more power all round and top end.
ChampionRC is offline
Old 03-25-2014 | 06:58 PM
  #6499
nickdawg18's Avatar
Originally Posted by houston
use .70mm shimming and you are good , you can take them down to .60mm if you think its necessary , they come at .80mm for break in
Would this be the same for a plus 4 btts?
nickdawg18 is offline
Old 03-26-2014 | 07:48 AM
  #6500
Motorman007's Avatar
Anyone try this carb yet
http://www.mugenseiki.com/novarossi_...etor_24066.htm
Motorman007 is offline
Old 03-26-2014 | 11:06 AM
  #6501
I have a question on Novarossi P5. I am in the process of breaking in a new one. The engine is smooth on idle and generally makes good impression except for bering bump box killer.. It needs now to be preheated to min 90 C to get turnover... Yesterday, I dismantled it to examine how the break in process was going on. The piston/sleeve both are a mirrow, however there are several hairlines and a couple of more serious dings on the backplate and conrod.
I am quite technically literate but do not have much experience in nitro engines, however my idea is that rubbing the concord against the backplate might be something wrong as the aluminium powder might be pumped into combustion chamber causing premature wear of the working surfaces of the piston/sleeve..
Please let me know how yr backplate/conrod looked like after the break in especially on Novarossi. Other comments on what might be wrong and how to correct it are welcome!
Matroskin1975 is offline
Old 03-26-2014 | 01:59 PM
  #6502
PERROTTO's Avatar
It doesn't look too bad. The crank may have been pushed in slightly when you installed the tapered cone for the flywheel/clutch. Make sure you pull the crank outward as much as possible when you seat the tapered cone onto the crankshaft.
PERROTTO is offline
Old 03-26-2014 | 02:20 PM
  #6503
houston's Avatar
houston is offline
Old 03-26-2014 | 06:31 PM
  #6504
Default Thanks
Thanks, I will certainly check it out
Old 03-28-2014 | 08:48 AM
  #6505
Kevin_M's Avatar
Default Keep off break in
Hello all I have recently bought the keep off for my buggy and will attempt the break in when the weather dries out and warms up.
This is my first nova motor and my question is, After break in is done do you remove any head shims for running 30% or keep the shims in?
Kevin_M is offline
Old 03-28-2014 | 02:18 PM
  #6506
beidle99's Avatar
Kevin,
once the engine reaches the 2 gallon mark you can remove a .2 shim and add a .1 shim to bring the deck height down to .7 if you need to, but most don't even mess with the shims.
beidle99 is offline
Old 03-28-2014 | 05:57 PM
  #6507
kgombe's Avatar
what this guy says^^^ if you find like the bottom is not what you want go down to 0.7.. i usually do it at the 3 gallon mark
kgombe is offline
Old 03-28-2014 | 08:05 PM
  #6508
Kevin_M's Avatar
Originally Posted by beidle99
Kevin,
Thanks Nick. Ill try to remember that when I reach that gallon mark. But with this weather and my schedule i hope i can get it broken in. lol
Kevin_M is offline
Old 03-29-2014 | 05:08 PM
  #6509
Kevin_M's Avatar
Got 2 tanks in today running great so far. Its starting up nicely and idling great. Keeping it nice and rich ill try to run a few more tanks in tomorrow.
Kevin_M is offline
Old 03-30-2014 | 03:56 PM
  #6510
What does the Werks 2058 pipe go like on the Keep Off 7?
For truggy.
Cheers
bartnz is offline
