NOVAROSSI Engine thread....
#7247
#7250
#7257
of course Pulse
not too many in this world know more on novarossi engines than i do , i pride myself on knowing the info
hope that helped , its a perfect rich starting point
check your hsn for obstructions if you are having problems getting the engine to tune in after checking and/or replacing your fuel delivery system
#7258
#7259
of course Pulse
) and I feel I lost the tune a bit so rather restart from the beginning.. I just cleaned everything inside the engine again, the pipe (2096), installed a new filter, rebuilt the clutch.. just too see if I can do a few more miles with this engine noob questions:
- what venturi size do you recommend for the BTT(running the 7 right now)?
- do you set the end points (idle,..) with the venturi installed or not?
thanks again!
352Likes
