NOVAROSSI Engine thread....
#7096
I run a Keep Off 7 with a 2013 in buggy and the bottom is just to much (modded engine keep in mind) but other then that I love the Werks pipe on the Nova engine. Its lighter then most pipes and is ballistic on the engines. I'll be trying a 2058 and have great faith it will be an awesome combo! If I were you I would try the 2058, heard it gets good mileage too.
#7097
I'm not sure you will be provided the answer your looking for - if you re-phrased the question to 'where are you needles after tuning' you'd get a better idea.
I've just run in my P5 and given it a safe tune:
7mm Venturi
HSN +3 hrs from flush
LSN +4 hrs from flush
That's running at circa 100/230 degrees with Byron 25-% with the ambient temp 20/70 degrees.
7mm Venturi
#7098
#7099
Hey guys, just for my testing and curiosity. I want to test out running 40% nitro in a Nova keep off 7. I have one that has been used a bit but still in very good shape and is perfect for testing grounds. From stock I removed 1 shim to get a little more power. So right now I run 1 less shim than stock on 30% with a hot plug. What will I need to do to properly run 40% at this point? Should I add 2 shims and run a colder plug and test from there? I don't want any pre detonation most importantly. Any help would be greatly appreciated and I'll report back with the results
I know you guys would totally advise against this but I want to try it
#7100
Just try a cold plug for now. Then you can start tolean it out as you ar esupposed too. When you use a hot plug, you advance the timing alot and this will actually give your engie less topend power. Your torq could be good from low end, but as soon as you hit some rpms, it will loose power and run hot. espesially since you already have removed a shim. if you are to test with 40%, make shure you add some shims and use a cold plug.
#7101
Awesome thanks man. Regarding plugs, how come so many guys ru nP3 and P4 then, dont they worry about losing top end? Question is how minimal is the loss in top end? The Keep 7 is a top end motor so to speak so prob not that noticeable? Maybe Ill run a P4 instead of the 3. I didnt like the Nova c6 that everyone suggests, didnt run strong enough or consistent enough.
#7102
What type of pipe would you guys recommend for a P5XLT in a buggy? Had my btt snap its rod last weekend and I'm in the market for something new. I ran a 2058 with the btt, would it be decent with the P5? I plan on running a 14t clutch bell also to smooth it out on the buggy. Thanks.
#7103
Now I haven't run it on a P5 but I know for a fact that is does exactly that on Werks and Orion motors. I guess we will see soon.
But if you want a Nova pipe, the 9901 pipe with the 41021 header is said to be one of the best all around set-ups for power, smoothness and fuel mileage.
#7104
I have been asking the same question as I have a P5 on the way now. From what I was told, the 2058 is great for smoothness and fuel mileage but its also is a power house. Its said it will provide plent of bottom end and screams on the top.
#7105
http://houstonsengineservice.com
#7107
#7108
#7109
25.8 rear and i like Boca ceramics for my replacement bearings.. works great, and they last the life of the engine..
352Likes
